Heya guys,
I recently bought the ASUS M5A97 Pro, installed an ssd on it, installed Windows on the ssd, everything fine up till now. Thing is, before doing all this, I had an older mobo that was set to use SATA in IDE mode, not AHCI, like the new one.
The old HDD that was installed on the old mobo doesn't boot along with the ssd, on the new mobo, even though I connected it to a SATA port that was set to run as IDE SATA, and the ssd to AHCI SATA. Despite this, the HDD only boots if the ssd is not connected to the mobo...
What I tried to do: boot live Ubuntu from a USB stick, delete the Windows and Linux(+ swap) partitions from the HDD. I succeeded in deleting the Windows partition, but the Linux refuses to be deleted, for some reason 0.o
So now I'm left with is an HDD that has an "Unknown" kind of partition after trying to delete Linux off it. Btw, the Linux partition isn't mountable anymore, so I did fuck smth up, I just don't know what...
What I think the problem is: when I installed Windows on the HDD, the mobo wasn't set to AHCI, and now, when I try to boot it off an AHCI enabled mobo, it doesn't recognize the disk (weird thing is, I DID set the specific port to use IDE, but it still doesn't work)
Also: both the ssd and hdd are partitioned using MBR.
So my question is: Why on Earth doesn't the HDD, which is connected to a sata port set to IDE, not AHCI, get recognized when booting up( I mean it's not even listed as "connected" in the BIOS)?
Sorry for the awfully long post, but I had the explain the whole weirdness that's happening...
