Hi, sorry if my English is bad as it is not my first Language but I have a small problem With a brand New gaming rig.
It has an ssd for the OS and an HDD, but the hdd does not show up in the Directory, even though if you og into the bios it is there. If you og into the Directory settings it shows. http://i.imgur.com/1OFspb7.png
You'll need to initialise it and format it http://pcsupport.about.com/od/tipstricks/f/format-hard-drive.htm
It's in Disk Management.
