HDD disconnecting issue
*using a USB hub solved the issue
Is there any chance the USB cable is faulty? Or a flaky port on the drive end?
Because that symptom sounds to me like a flaky USB connection.
Also, check the SMART stats of your drive.
Just reconnected it with a new cable to make sure it wasn’t that.
The smart looks ok to me.
I will give it a go in another computer and see if it’s maybe a motherboard issue, but I highly doubt it
