HD7950 vs R9 270
Here in the UK, the 7950 and the R9 270 are pretty much the same price. I've been looking to upgrade from my pitiful 7770.
Which one would you recommend, from Linus' new video the 7950 out performs R9 270 so would that be the best choice?
R9 270 is basically a 7870XT so the 7950 is definitely better.
Historically AMD drivers have be FAR from optimal at launch, so thats something to keep in mind.
The 7950 is a excellent proven card, and the R9 270 is still a bit of a unknow.......I wouldn't feel comfortable recommending one card over the other this early on.
Good luck, and sorry I couldn't be more help!
Yep the HD7950 is better but here is some benchmarks for that card.
7950 because it beats the 270x out of the box. and if you oc the 7950 it performs as well as 770 and 7970
<----- Devils advocate
Tough, what do we know about the OC performance on the 270X?
its a re-brand of the 7870 Ghz edition..thats what we know.
If you oc a 7870 Ghz edition its going to hit 7950 speeds.
and if you oc a 7950 its going to hit 770 speeds and surpass 7970.
just like the 280x is a rebrand of the 7970 Ghz edition.
It performs as well as the 7970 Ghz edition and oc the same.
dont know what miracle you wishing to come from this re-brand card.
I'm not wishing for a miracle form this card, I don't have a vested interest in the 7950 or the 270X !?
I just think its a huge oversimplification, and somewhat misleading to say the 270x and 280x are just rebranded 7870 & 7970 cards.
Its a rebrand of the 7870 card its stock perfomance is the same as the HD 7870XT club 3d joker card.
The core clock speed of the R9 270X is 1.05 GHz (up to, thanks to Turbo clocks) which gives it a 50 MHz increase over the HD 7870 GHz Edition.
As a result, the theoretical peak performance jumps a bit from 2.56 TFLOPS to 2.69 TFLOPS as does board power from 175 watts to 180 watts. The 256-bit memory bus is running at a noticeably higher speed though: up to 5.6 GHz from 4.8 GHz which should push memory bandwidth up to 179.2 GB/s.
But again, the other specifications remain the same. That means a 2.8 billion transistor 28nm chip with 1280 shader cores, 80 texture units and 32 ROPs. The memory bus is backed by 2GB of frame buffer by default but you can expect to see 4GB options
You just read Ryan Shrout review on PC Perspective too? :)
I know i am real glad i went ahead and got my second 7870 for cheap . I am impressed with the HIS coolers.
Yep....i am probably going to get one of these two cards while there cheap TBH just havent havent made my mind up yet.
http://bit.ly/15ezarw
http://bit.ly/13QeXJU
I will probably get the AMD card because of all those upcoming 'next gen' games comeing AMD optimised.
Wow that a really good price for the new revision MSI HD7950 TwinFrozr,under £200!
Dat frame time!
if they ship to US i might just pick me up a second 7950 and xfire them bad boys..then i wont be getting the new (i mean re brand) 280x if i do so...hmm mantel or no mantel...hmmm...
In a few month the 7970 will be dropping in price. $280 isn't a bad bang for buck.
nope right now that's available
 http://www.newegg.com/Product/Product.aspx?Item=N82E16814127732
