HD 7950 vs R9 270X
If you had to choose between these two:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127737
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127761
Which one would you take and why? Huge, in-depth responses are welcome.
The price difference is $ 60 - about 45 euro.
7950. The 7950 is closer to the 280x. A decent overclocking 7950 is pretty much equal to an overclocked 770. But you will need a better cooling solution.
The R9 series is largely rebranded HD series cards like the 7950. Though, it is a reference design, which sucks. Reference designs are easier to fit with a waterblock!
Seeing as how the 280x is $100 more than the 270x, I would just go with that instead of the 7950. And that is exactly what I did do a little while ago in your situation. That is, if you can find it at the original price (which I managed to do, thankfully). It really depends on what you want though. Personally, I don't really think that the 7950 would be worth the extra money over the 270x, but that might be different for you. Another option would be to wait until Feb when nVidia is supposed to launch my gpus.
 R9 270X (a HD7870 with a new sticker on it) you do realize both cards are out of stock anyway and when there back in stock prepare for a masive price hike.....
Well, these are the prices i can get:
MSI 270X $253
MSI HD7950 (shitty cooler) $314
Sapphire R9 280X $410
From a price/performance standpoint - what would you buy? Right now I have exactly enough to buy the 7950, but I could save up and buy the R9 280X? But is it worth the $96 price difference?
Would buying the R9 270X and selling it later to buy the 280X make more sense?
There's also the GTX 760 (http://www.newegg.com/Product/Product.aspx?Item=N82E16814127745) but it's $331. For some reason Nvidia cards are overpriced here.
That 760 is 264. I'd get that.
Oh wait. You're using Euros. It would be better to just tell us where you're going to buy from, and not post Newegg prices. It makes it so much harder. What is your budget in Euros?
I have 230 Euros. Also, I'm not buying from the EU, but in my country, Bosnia - it's a pretty fucked up country (40% unemployment rate) and I believe I'm regarded as upper middle class here.
EDIT: It's actually 44%.
I'm looking at Italian prices, which are comparatively higher than Germany. Don't know if Italian prices reflect Bosnian prices. They have 760s priced around 230 euros.
280x = 7970 = 770 > 7950 > 760 > 270x = 7870
I cannot tell you which is best for you. The 270x and 7870, being the weakest of the considered cards, will play most games on ultra settings. I'm sure that you will be happy with any single card. But you would have to determine what is best for your needs. I believe the 280x is quite a bit faster than the 270x, but you will have to decide if it is worth the price difference.
Thanks.
What do you think would be easier to sell (will return the most money) - the 270x or the 7950?
I'd snap up a GTX 760 tbh...i would not be buying a card whanting to sell it as a investment.
There are two factors rigth now makeing gpus expencive (maybe 3) one is the 60% rise of flash chip costs since the Hynix factory fire and the second is the latest scrypt mining (bitcoin mining) craze that will fall flat on its face at some point.
More miners = harder to mine = no longer viable to make a proffit out of it.
Lastly there are the retalers takeing advantage of the craze slaping extra on top and takeing advantage of the gpu shortages.
If it was 2-3mths ago i'd of sead grab a HD7970/R9 280X becase thay where a lot better price to performance.
Grab a GTX760 and enjoy it...it isent a bad card it can handle 1080p resolutions at maxed out setings in 95% of the games out rigth now.
So the GTX 760 faster than the HD 7950? I'd like to use Skyrim HD mods - that 3GB VRAM could be useful.
If you are looking at nVidia (meaning that Mantel isn't a priority for you) then you might want to hold off. 800 series should be coming in Feb.
The HD7950's party piece is that its a extremely good overclocker stock to stock the cards win in differnt games so if you are going to buy a HD7950 that has a crapy cooler on it overclocking is out the window with it anless you try adding aftermarket cooling which is a extra expense to think about.
I think that might be the mobile 800s, not the desktop cards.
Oh, crap I totally forgot about Mantle. Also, the 7950 has more VRAM and it's 384 bit.
On the other hand the GTX760 has a better cooler.
Damn, why is this so hard!
get the 760... it's not that hard :P
7950 is a way better card then the GTX760, but since the bitcoin mining is still a hype, the 7950 will probably a bit expensive.
I got my 7950 a month before the new gpu series came out (Augest), and i got it at a cheaper price then the the 760 ($250 vs $260), and got over $180 in games.
