HD 5700 Series
HD 5770 and the Hd5750 are posted on Newegg and on sale. look at the specs!
Radeon HD 5770
Core Clock 850MHz
800 Stream Processing Units
Memory Clock 1200MHz (4.8Gbps)
Memory Size 1GB
Memory Interface 128-bit
Memory Type GDDR5
3D API DirectX 11
Ports
HDMI 1
DisplayPort 1
DVI 2
General
RAMDAC 400 MHz
Max Resolution 2560 x 1600
CrossFire Supported Yes
Cooler With Fan
Dual-Link DVI Supported Yes
HDCP Ready Yes
Features
ATI Eyefinity TechnologyGPU
Radeon HD 5750
Core Clock 700MHz
Memory Clock 1150MHz (4.6Gbps)
Memory Size 1GB
Memory Type GDDR5
DirectX 11
Ports
HDMI 1
DisplayPort 1
DVI 2
General
RAMDAC 400 MHz
Cooler With Fan
HDCP Ready Yes
Pretty much a 4870 with DX11
eye infinity
display port
40nm
faster core
faster memory
but lower memory bus... -.-
but the hd 4870 is still a beast of a card.
HIS used to have 4870's with the same clocks. And the memory bus being half the size of a 4870 makes it that much equal in benchmarks.
It's basically the HD4870/HD4850 killer with less power consumption. However with that said, it's still not worth it if you have either of those cards.
I am thinking about getting 2 of the 5770's for my next build. not sure yet. just have to wait and see what nvidia comes out with.
