i am having problems overclocking my 4850, it the palit 4850 http://www.palit.biz/main/vgapro.php?id=853 i can only overclock it from 625mhz to 635 and memory clock speed from 1986 to 2082 isint there away that i can overclock it higher. the tempreatures are stable idle at 34C and at full load only 58C.
here is my computer spec antec nine hundred case e7200 cpu 2.5ghz overclocked to 3.75ghz 4gb ddr2 overclocked at 920mhz geal edtion asus p5q l pro p43 chipset motherboard antect earthwatts powersupply 500 watts (good expensive quality powersupply bought for £65 thats about $80 to $100
I like your Kazama avatar. Lol. Tekkennnn. But yeah, or it could definitely be your chip. Sometimes people get duds. None of em are ever QUITE the same. Some are better, some are worse. Have you done a fresh reinstall of drivers? And what utility are you using to overclock your 4850?
