Okay so my little sister will be turning 18 this december and she has her hearts set on a pink desktop built by me... Some how I ended up paying for this...xD
niether the mobo nor the ram will be available in pink in most cases, but you could always supplement it with a lot of pink led fans lol. and for a processor id go with the fx-8350,
also i would go with http://www.newegg.com/Product/Product.aspx?Item=N82E16814125463 rather than the 660s its double the price but does not suffer the performance drop from sli that you do when you have two cards of equivalent price. note in example company of heroes two doesnt support sli in the event a game doesnt you are SOL.
Yes she will be OC'ing it...i need to edit that I plan on adding water cooling to it too...
And well budget isn't really a consern to me...
I more conserned about it being pink as that's what she wants....I guess the GPU preferably would like the cost to stay under 450$ ish...or 500$. The motherboard will need to support sli or crossfire at least and needs to be able to OC...and CPU has to be an unlocked one to OC with...also bmin2709 the case only supports up to 16Inch long GPU's is that longer than 16inches? O.o
Most of the parts in this build are red, thats the closest i could get to getting pink hardware(also the fans on the case have red led's). As bmin said the 770 would be a better choice over two 660's due to lower power consumption. And the 770 can handle its self at 1080p easily.You could swap out the dark night for a TC12DX (red in colour) if you don't like the black colour of the dark night.
http://pcpartpicker.com/p/1mCJM
Edit: changed out the 2gb evga with a 4gb 770. Only 10 dollars more than the gigabyte and not voltage locked.
also i would go for the 4gb version of the gigabyte card i listed if she plans on doing multimonitor gaming. its $449.99 and no lol its not over 16 inches the largest ive seen is like 12.5 and thats a 7990 lol
Lol well thanks both of you! :) I think I'll get a GTX 770 she does 1920x1080p on a 24inch led tv but likes to max out the settings in the game...xD and I think i'll get the i5 4670k cuss she doesn't do any streaming or video recording stuff....if she did then i'd get the fx amd CPU as its better with multitasking. and thanks good to know that it will fit in the case...the motherboard I think i will go with that and the red ram I think it will look okay with the pink leds that i'll be getting...if it doesnt then oh well i'll just order more parts....:P
lol nice hope everything goes smothe for you! :) Hope my sis likes her PC. I will be ordering the parts every month till december then will throw it togther sometime before the 22nd probably around the 12th...and will install win7 64bit OS. Don't think she'd like win8...xD cuss I sure as heck don't.... Sadly I'd like to order all at once but i have to pay the pills too...But at least I have a way to test all the parts that I order so I at least know if something is bad or DOA....
