Hey everyone, I’m setting up my first kvm to game on, It’s GPU passthrough but having some issues when playing games it will give random lagspikes or sometimes even my audio completely changes to another input making the game completely crash till i change it back properly. Does anyone happen to know a fix for this?
My specs :
CPU: Intel Core i9-7920X
GPU: GTX 2080 ti & GTX 960
Ram : 32 gb ddr4
Host is Arch linux
I’m passing through the 2080ti together with 8 cores, 16 threads & 16gb of ram.
My XML config :
XML Config
<domain type="kvm">
<name>awaaa</name>
<uuid>5ba0bef0-09a2-4a2a-ba4f-54b67bdf9f52</uuid>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://microsoft.com/win/10"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">16777216</memory>
<currentMemory unit="KiB">16777216</currentMemory>
<vcpu placement="static">16</vcpu>
<iothreads>1</iothreads>
<cputune>
<vcpupin vcpu="0" cpuset="2"/>
<vcpupin vcpu="1" cpuset="8"/>
<vcpupin vcpu="2" cpuset="3"/>
<vcpupin vcpu="3" cpuset="9"/>
<vcpupin vcpu="4" cpuset="4"/>
<vcpupin vcpu="5" cpuset="10"/>
<vcpupin vcpu="6" cpuset="5"/>
<vcpupin vcpu="7" cpuset="11"/>
<vcpupin vcpu="8" cpuset="6"/>
<vcpupin vcpu="9" cpuset="12"/>
<vcpupin vcpu="10" cpuset="7"/>
<vcpupin vcpu="11" cpuset="13"/>
<vcpupin vcpu="12" cpuset="8"/>
<vcpupin vcpu="13" cpuset="14"/>
<vcpupin vcpu="14" cpuset="9"/>
<vcpupin vcpu="15" cpuset="15"/>
<emulatorpin cpuset="0"/>
<iothreadpin iothread="1" cpuset="0"/>
</cputune>
<sysinfo type="smbios">
<bios>
<entry name="vendor">METICK</entry>
</bios>
<system>
<entry name="manufacturer">METICK</entry>
<entry name="product">Metick</entry>
<entry name="version">1.0.1</entry>
<entry name="serial">Metick</entry>
<entry name="uuid">5ba0bef0-09a2-4a2a-ba4f-54b67bdf9f52</entry>
<entry name="sku">SHEESH</entry>
<entry name="family">Metick</entry>
</system>
<baseBoard>
<entry name="product">MetickV</entry>
<entry name="version">1.0</entry>
<entry name="serial">metick</entry>
</baseBoard>
<chassis>
<entry name="version">1.01</entry>
<entry name="asset">9010004</entry>
<entry name="sku">typeMetick</entry>
</chassis>
</sysinfo>
<os>
<type arch="x86_64" machine="pc-i440fx-6.0">hvm</type>
<loader readonly="yes" type="pflash">/usr/share/edk2-ovmf/x64/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/awaaa_VARS.fd</nvram>
<boot dev="hd"/>
<smbios mode="sysinfo"/>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
<vpindex state="on"/>
<synic state="on"/>
<stimer state="on"/>
<reset state="on"/>
<vendor_id state="on" value="cAb6Z9623a9"/>
<frequencies state="on"/>
</hyperv>
<kvm>
<hidden state="on"/>
</kvm>
<vmport state="off"/>
<ioapic driver="kvm"/>
</features>
<cpu mode="host-passthrough" check="partial" migratable="on">
<topology sockets="1" dies="1" cores="8" threads="2"/>
</cpu>
<clock offset="localtime">
<timer name="rtc" tickpolicy="catchup"/>
<timer name="pit" tickpolicy="delay"/>
<timer name="hpet" present="no"/>
<timer name="hypervclock" present="yes"/>
<timer name="tsc" present="yes" mode="native"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type="file" device="disk">
<driver name="qemu" type="qcow2"/>
<source file="/var/lib/libvirt/images/awaaa.qcow2"/>
<target dev="sda" bus="sata"/>
<serial>metickACutie</serial>
<address type="drive" controller="0" bus="0" target="0" unit="0"/>
</disk>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x00" slot="0x05" function="0x0"/>
</controller>
<controller type="pci" index="0" model="pci-root"/>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x06" function="0x0"/>
</controller>
<controller type="virtio-serial" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x07" function="0x0"/>
</controller>
<interface type="network">
<mac address="52:54:00:b0:5c:43"/>
<source network="default"/>
<model type="e1000e"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x0"/>
</interface>
<serial type="pty">
<target type="isa-serial" port="0">
<model name="isa-serial"/>
</target>
</serial>
<console type="pty">
<target type="serial" port="0"/>
</console>
<input type="evdev">
<source dev="/dev/input/by-id/usb-Corsair_Corsair_Gaming_GLAIVE_RGB_Mouse_0A013018AF08984858ADF5D7F5001946-event-mouse"/>
</input>
<source dev="/dev/input/by-id/usb-Razer_Razer_BlackWidow_X_Chroma-event-kbd" grab="all" repeat="on"/>
</input>
<input type="mouse" bus="virtio">
<address type="pci" domain="0x0000" bus="0x00" slot="0x04" function="0x0"/>
</input>
<input type="keyboard" bus="virtio">
<address type="pci" domain="0x0000" bus="0x00" slot="0x0c" function="0x0"/>
</input>
<input type="mouse" bus="ps2"/>
<input type="keyboard" bus="ps2"/>
<audio id="1" type="spice"/>
<hostdev mode="subsystem" type="pci" managed="yes">
<source>
<address domain="0x0000" bus="0x17" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x00" slot="0x09" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x17" slot="0x00" function="0x1"/>
</source>
<address type="pci" domain="0x0000" bus="0x00" slot="0x0a" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x17" slot="0x00" function="0x2"/>
</source>
<address type="pci" domain="0x0000" bus="0x00" slot="0x0b" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x17" slot="0x00" function="0x3"/>
</source>
<address type="pci" domain="0x0000" bus="0x00" slot="0x0e" function="0x0"/>
</hostdev>
<hostdev mode="subsystem" type="usb" managed="yes">
<source>
<vendor id="0x1220"/>
<product id="0x8fe0"/>
</source>
<address type="usb" bus="0" port="1"/>
</hostdev>
<source>
<vendor id="0x1038"/>
<product id="0x1294"/>
</source>
<address type="usb" bus="0" port="5"/>
</hostdev>
<redirdev bus="usb" type="spicevmc">
<address type="usb" bus="0" port="2"/>
</redirdev>
<address type="usb" bus="0" port="3"/>
</redirdev>
<memballoon model="virtio">
<address type="pci" domain="0x0000" bus="0x00" slot="0x08" function="0x0"/>
</memballoon>
</devices>
</domain>
