When I try to run steam on my ubuntu 14.4 install I get the following error:
Steam needs to install these additional packages: libgl1-mesa-dri:i386, libgl1-mesa-glx:i386, libc6:i386 [sudo] password for atcop12: Sorry, try again. [sudo] password for atcop12: ............................................................................................... Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: libgl1-mesa-glx:i386 : Depends: libglapi-mesa:i386 (= 10.1.3-0ubuntu0.6) E: Unable to correct problems, you have held broken packages. Press return to continue:
Hey Tex that has sometimes been a issue with steam on ubuntu. Try running this in the command terminal sudo apt-get install libc6:i386 libgl1-mesa-dri-lts-utopic:i386 libgl1-mesa-glx-lts-utopic:i386
The following packages have unmet dependencies: libgl1-mesa-dri-lts-utopic:i386 : Conflicts: libgl1-mesa-dri libgl1-mesa-glx-lts-utopic:i386 : Depends: libglapi-mesa-lts-utopic:i386 (= 10.3.2-0ubuntu1~trusty2) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
If this is your first time in Ubuntu I would also run sudo apt-get install aptitude Aptitude is a program that can help fix issues you may have down the road and does not require you using the GUI. So if something breaks the unity GUI you can always use aptitude to fix the issue in command line and get back up and running. But to me just sounds like Ubuntu has not been updated
That's because the tee command is a program that copies its input to both the screen and the file. You can use it to pipe data into files in Linux. Because each command needs the sudo command, you can't use a > or >> to append to a file, because you can't do sudo >>, but it will work with a | sudo tee <file>.
