I just started using Manjaro and am having problems with my Da Vinci Resolve install. Basically, the installation works fine, I’ve installed the software and the correct drivers (I think) but whenever I try to run the software it starts loading, it even goes as far as to open the “Da Vinci Resolve” loading screen but the software itself doesn’t open and shuts down while “looking for control surface”. I’ve tried running it from terminal but all I get is this:
[akio@akio-pc ~]$ /opt/resolve/bin/resolve
ActCCMessage Already in Table: Code= c005, Mode= 13, Level= 1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= c006, Mode= 13, Level= 1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= c007, Mode= 13, Level= 1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= 2282, Mode= 0, Level= 0, CmdKey= 8, Option= 0
PnlMsgActionStringAdapter Already in Table: Code= 615e, Mode= 0, Level= 0, CmdKey= -1, Option= 0
15.3.1 (#003) Linux/Clang
Main thread starts: A1CA4080
[0x7fcfa1ca4080] | Undefined | INFO | 2019-05-15 18:47:54,745 | --------------------------------------------------------------------------------
[0x7fcfa1ca4080] | Undefined | INFO | 2019-05-15 18:47:54,745 | Loaded log config from /opt/resolve/configs/log-conf.xml
with not even an “aborted” message nor anything.
My current setup is a Ryzen 2600 with an RX580 running Manjaro KDE. Can anyone help me? Should I just switch over to a more “begginer friendly” distro like Ubuntu? Or is there something I’m missing?
Thanks in advance.
