Right, so I got my second GTX 970 this morning, and had to move my network card to the top slot so it would fit below my first card. Weird thing is, when I have both graphics cards plugged in, it's like the PCI-E slot that my network card is in just disabled. The only network device that shows up in my network connections is my ethernet port. Why is this? I'm not going to swap my graphics card in and out whenever I need to use the internet. :|
Help plz.
Edit: I have tested multiple times, the network card works perfectly fine when the second graphics card is taken out but doesn't seem to exist when it's in.
ai your motherboard is the problem. Your B150 chipsetboard does not support Sli. So you wont be able to utilize Sli. You need a Z170 chipset board to be able to use two Nvidia cards in Sli.
Still weird that your pci-e X1 lan card gets disabled, but it might have something to do with that.
Because the B150 chipset does not support sli. The first pci-e x16 slot is connected with 16 lanes, and the second pci-e x16 slot is connected with 4 lanes. For Sli you need a minimal of 8 lanes per slot. And therefor Sli will not work.
Only Z170 chipset supports sli. But also even not all Z170 boards support sli. The cheaper Z170 boards mostly dont.
Well, blame whoever put it together for chosing those odd parts, dunno if you can still return most of it, but you could end up with a fair better build I think
Otherwise you'd need a motherboard upgrade, or to sell/return the 970s for AMD cards
Also if you aren't using DDR3L you should stop using your PC until you lower the voltage on your RAM or get proper DDR3L memory, DDR3 isn't supported and may cause damage
Yes please, something midrange, not too cheap, not too expensive. Is that the only thing I need to change? I'm running 4x4GB Corsair Vengeance 1600MHz DDR3
