I have a Saitek ST290 Pro. I am trying to play the Rise of Flight demo but it is impossible to play because the Z rotation (yaw) on my joystick is constantly going right. I have tried downloading drivers and calibrating but it doesn't work. I think this may be a mechanical problem, so is there a way it can be fixed? If not, it may be time for a new joystick.
If you're using it for the first time, (maybe you built a new PC, etc etc) it could just be a hardware compatibility issue. My Madcatz Tournament Edition only works on Intel chipset motherboards. As my current PC is an Nvidia chipset that uses a different USB controller, I'm out of luck. So I'm forced to use my other PC downstairs with the Gigabyte p45 mobo whenever I get the urge to play old Street Fighter arcade games.
