Having issues with DXtory and low write file FPS, really need help
So for some reason as of late I've been having issues with DXtory and not being able to record with an acceptable file write frame rate.
The game itself can play at 60FPS+ but the frame rate of the file is completely trash. Less than 10FPS now.
This only started recently, probably a few weeks ago.
The specific issue I'm having is that If I start recording, regardless of codec, drive selection, or anything in the settings the file write frame rate(the video itself) is extremely low, right now I can't seem to get it to go above 10FPS.
Previously if I could get DXTory to record at any frame rate up to 60FPS and I did so with this video to show a bug error: https://www.youtube.com/watch?v=wZsCv8410Kw
In the youtube settings you can watch the video at 60FPS.
This was only a month ago that I recorded this video.
Now I can't get more than 24FPS in any video I am trying to record.
This morning I installed new AMD Drivers for my GPU, and the updated drivers didn't solve the issue. I uninstalled programs and tested settings with in other programs and I can't seem to get anything to work properly with DXTory now.
I posted on their forums specifically, and for some reason my post was removed and I can't post now at all. I'm really lost as to what to do.
Info from DXTory
========== 2015/05/21 16:23:24 ==========
PID:6068 D:\WildStar\WildStar\Client64\WildStar64.exe (x64)
PID:6068 TID:6000 TickCount: 49639 HU_SetHookCode Fail CalcCodeSegment
PID:6068 TID:6000 TickCount: 49639 Fail HOOK_CODE IDXGISwapChain_Present HookDXGI.cpp(31)
PID:6068 TID:6000 TickCount: 49639 dxgi.dll 176888
PID:6068 TID:6000 TickCount: 49639 FF 25 00 00 00 00 00 6E 55 02 00 00 00 00 EC B0
========== 2015/05/21 16:45:15 ==========
PID:5232 C:\Program Files (x86)\Dxtory Software\Dxtory2.0\Dxtory.exe
PID:5232 TID:7104 TickCount: 1360375 MMFile::Init Fail MapViewOfFile name=ProcessComm_sharemem_6484_55 size=-1 err=8
[Dxtory]
Version: 2.0.122
UID: 18d8f467-5963-42e7-9def-60bf791da14c
[Dxtory Files]
InstallPath: C:\Program Files (x86)\Dxtory Software\Dxtory2.0
AudioStreamSplitter.exe: FileVersion: 1.0.0.0 SHA1: f2f729dc20a4f399704e99beeca855e85e5b9286
AVIFix.exe: FileVersion: 2.0.0.119 SHA1: 7a09d66397e59a821aa710e53f9e241f77a7792a
AVIMux.exe: FileVersion: 2.0.0.120 SHA1: 5196d86b22e66459b4dececc675099f8dd16422b
AVIMuxCore.dll: FileVersion: 2.0.0.3 SHA1: 77f91e5cbdb6516492937b09e8779fbfce339ad0
Dxtory.exe: FileVersion: 2.0.0.122 SHA1: 00d54133c207095e5295368f24186d933257d2df
Dxtory64.exe: FileVersion: 1.0.0.60 SHA1: 14e3f06e6f2afb2dcb8dec2813586253fc58d86b
DxtoryAudioHelper.dll: FileVersion: 1.0.0.79 SHA1: 1e11c70e2f744fe9fcb95402c955d14f3d9503ce
DxtoryCore.dll: FileVersion: 2.0.0.122 SHA1: bac6c8055f3612f9e7eca5bc32dac79b787e1a86
DxtoryCore64.dll: FileVersion: 2.0.0.122 SHA1: 11b4a0095aeba166563095c9c4207c868c90ae5b
DxtoryHK.dll: FileVersion: 2.0.0.121 SHA1: 0917315496e3c6fad5c171ae730cb9f7a3eddda5
DxtoryHK64.dll: FileVersion: 2.0.0.121 SHA1: ed965a2f95b156329cfe8f12c58415e05ad282c0
DxtoryMM.dll: FileVersion: 1.0.0.1 SHA1: 82eeaf2ec6ddd70f887ea5e20a80be718600b230
DxtoryMM64.dll: FileVersion: 1.0.0.1 SHA1: c142da021338ef96d13dc82c70c6ba2a443d1108
DxtoryVideo.dll: FileVersion: 2.0.0.97 SHA1: b9c1ff13a061e189affef9ae37f5ae142450b189
DxtoryVideo64.dll: FileVersion: 2.0.0.97 SHA1: 497ef3f62908d7a1f9362fc347198b900fc7c131
DxtoryVideoSetting.exe: FileVersion: 2.0.0.119 SHA1: adb248b7eca7001e64ba19054807ab6556126a87
LicReg.exe: FileVersion: 2.0.0.3 SHA1: d68fe1f3b1eb8c3a3e66af99810835f43ca40c59
RawCapConv.exe: FileVersion: 2.0.0.119 SHA1: fe5c173b64236219c1a464db3ae117a8d53deded
RCStream.dll: FileVersion: 1.0.0.76 SHA1: 31266452f142cd7c856384945ffc410b2c9c8be9
unins000.exe: FileVersion: 51.1052.0.0 SHA1: c46876d124ae3b93d64960eda6d6253a33639481
UpdateChecker.exe: FileVersion: 2.0.0.0 SHA1: 221bd3663f4393b368ebf74d1a892f9379ddbe44
[System Information]
CPU: Intel(R) Core(TM) i7-3740QM CPU @ 2.70GHz
CPU Instruction Set: MMX SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 AVX
OS: Microsoft Windows 7 Home Premium x64
OSVersion: 6.1.7601
OSLanguage: 1033
ServicePack: Service Pack 1
Memory0: BANK 0 4,294,967,296 bytes
Memory1: BANK 1 4,294,967,296 bytes
Memory2: BANK 2 2,147,483,648 bytes
Memory3: BANK 3 2,147,483,648 bytes
TotalMemory: 12,884,901,888 bytes
Total Physical Memory: 12,832,800,768 bytes
Available Physical Memory: 7,243,591,680 bytes
Total Page File: 25,663,700,992 bytes
Available Page File: 19,293,581,312 bytes
Total Virtual Memory: 2,147,352,576 bytes
Available Virtual Memory: 1,754,587,136 bytes
PerformanceCounterFrequency: 2630810 (0x28249A)
VideoCard: AMD Radeon HD 7970M Memory: 2,147,483,648 Processor: AMD Radeon Graphics Processor (0x6800) DriverVer: 14.501.1003.0 DriverDate: 2014-11-19 16-00-00
Display0: 3200x900 32bits 60Hz
SoundDevice: High Definition Audio Device Manufacturer: Microsoft
SoundDevice: Sound Blaster Recon3Di Manufacturer: Creative Technology Ltd.
SoundDevice: USB Audio Device Manufacturer: (Generic USB Audio)
[Audio Device]
Digital Output (Sound Blaster Recon3Di) - CoreAudioOut
Speakers (Skullcandy Slayer) - CoreAudioOut
Speakers (Sound Blaster Recon3Di) - CoreAudioOut
HDMI In (Sound Blaster Recon3Di) - CoreAudioIn, Volume 100
What U Hear (Sound Blaster Recon3Di) - CoreAudioIn, Volume 100
Microphone (Skullcandy Slayer) - CoreAudioIn, Volume 70
[Video Codec]
Dxtory Video Codec FCC:xtor
Cinepak Codec by Radius FCC:cvid
Intel IYUV codec FCC:i420
Intel IYUV codec FCC:iyuv
Microsoft RLE FCC:mrle
Microsoft Video 1 FCC:msvc
RivaTuner Video Codec FCC:rtv1
x264vfw - H.264/MPEG-4 AVC codec FCC:x264
[Audio Codec]
Microsoft IMA ADPCM
Microsoft CCITT G.711
Microsoft GSM 6.10
MS-ADPCM
PCM
IEEE Float
[License Information]
License: Registered
Expire: Unlimited
LicVerify: 9c975029511ad16b51bf5feb382a451f754579a7
[Additional Information]
Dxtory_log.txt: Empty
ErrorLog.txt: Available Size=1388
[Global Setting]
OptionFlag=
[Ignore List]
[Profile]
Path:
[Overlay]
Option: Right Bottom VidoeFPS WriteFileFPS RecordState
Color: Sleep FF7943FF, Active FFFFBC00, Movie FF00FF00, ScreenShot FF00FF00
[Folder]
x D:\fraps\Movies Speed: 74MB/sec Free: 50,530,635,776 Total: 750,153,363,456 Format: NTFS
F: Speed: 36MB/sec Free: 310,156,771,328 Total: 991,333,183,488 Format: NTFS
SSFolder: D:\fraps\Screenshots
[HotKey]
MovieCapture: Alt + \ (0x0008002B)
PushToTalk: None
ScreenShotSingle: Prnt Scrn (0x00010037)
ScreenShotRepeat: None
ScreenShotAuto: None
ToggleStatus: None
MovieCaptureFrame: None
ScreenShotCaptureFrame: None
[Movie]
Clipping:
ClipMargin: 0,0,0,0
ClipSize: 0,0
Scaling: Percent 100% 0x0
Codec: x264vfw - H.264/MPEG-4 AVC codec, Quality 10000, KeyFrameRate 15, DataRate 0
FrameRate: 60
Output: File AVI
Option:
[Audio0]
Enabled: True
PushToTalk: False
Device: Speakers (Skullcandy Slayer)
Codec: PCM
Format: PCM 48000 Hz, 16 bit, Stereo
[ScreenShot]
Clipping:
ClipMargin: 0,0,0,0
ClipSize: 0,0
HighSpeedLimit: 0
RepeatInterval: 1000
Format: BMP
JpegQuality: 97
Option:
[Advanced]
Option:
ThreadCount: 1
LimitedFPS: False
FPSLimit: 60
DelayHook: False
DelayHookTime: 5
[Profile]
Name: League of Legends (TM) Client
Path: D:\Addiction\RADS\solutions\lol_game_client_sln\releases\0.0.1.90\deploy\League of Legends.exe
[LastUsingInformation]
DateTime: 2015/05/23 22:01:27
DeviceType: OGL DX7 DX9 DX10 DX10.1 DX11
View0.Type=DX9
View0.DevType=D3DDEVTYPE_HAL
View0.BhFlags=D3DCREATE_HARDWARE_VERTEXPROCESSING
View0.Format=D3DFMT_X8R8G8B8
View0.Size=3200x900
View0.HWND=0x00B010FE
View0.WindowTitle=League of Legends (TM) Client
View0.ClassName=RiotWindowClass
[Profile]
Name: LoL Skin Installer +lgg v4.34
Path: D:\FranBunnyFFXII\Documents\Custom LoL\SIU 4.34-Lite\Skin Installer Ultimate.exe
DateTime: 2015/05/21 22:30:27
DeviceType: OGL DX7 DX11
View0.Type=OGL
View0.Size=956x41
View0.HWND=0x001A0EB4
View0.WindowTitle=
View0.ClassName=WindowsForms10.Window.8.app.0.33c0d9d
[Profile]
Path: D:\Addiction\RADS\projects\lol_air_client\releases\0.0.1.144\deploy\LolClient.exe
DateTime: 2015/05/24 10:14:45
DeviceType: DX9
View0.Type=DX9
View0.BhFlags=D3DCREATE_FPU_PRESERVE D3DCREATE_MULTITHREADED D3DCREATE_HARDWARE_VERTEXPROCESSING
View0.Size=1321x826
View0.HWND=0x00320EB0
View0.WindowTitle=PVP.net Client
View0.ClassName=ApolloRuntimeContentWindow
[Profile]
Path: D:\My Programs\TERA\Client\Binaries\TERA.exe
[Advanced]
Option:
ThreadCount: 1
LimitedFPS: False
FPSLimit: 60
DelayHook: False
DelayHookTime: 5
DateTime: 2015/05/21 16:36:06
DeviceType: DX9
View0.Type=DX9
View0.BhFlags=D3DCREATE_FPU_PRESERVE D3DCREATE_MULTITHREADED D3DCREATE_HARDWARE_VERTEXPROCESSING D3DCREATE_DISABLE_DRIVER_MANAGEMENT
View0.Format=D3DFMT_A8R8G8B8
View0.Size=3200x900
View0.HWND=0x00080DAC
View0.WindowTitle=TERA
View0.ClassName=LaunchUnrealUWindowsClient
[Profile]
Path: D:\WildStar\WildStar\Client64\WildStar64.exe
DateTime: 2015/05/24 20:58:17
64bit Process
DeviceType: DX11
View0.Type=DX11
View0.CreateFlag=D3D11_CREATE_DEVICE_PREVENT_ALTERING_LAYER_SETTINGS_FROM_REGISTRY
View0.FeatureLevel=D3D_FEATURE_LEVEL_11_0
View0.Format=DXGI_FORMAT_R8G8B8A8_UNORM
View0.Size=3200x900
View0.HWND=0x001A0BD0
View0.WindowTitle=WildStar 8618
View0.ClassName=WildStar 8618
VerifyHash: 87f097c5d62c750ae72259593eee0c8cb1d2e449
