So I think for my upgrade I'm going to end up grabbing an i5 3570K and Z77 since I'm going microATX so AMD's not really a suitable option (unless I wait awhile and get a Steamroller Athlon... but if I'm gonna upgrade this Q6600 I'd like it to be something that'll last for awhile). Plus I play Rift a lot so single-threaded performance is very nice :p
Is there any good reason to grab the 4670K over the 3570K? So far my reasoning for siding with the 3570K is that first off, the 3570K + Asus Z77 microATX mobo costs like $30 less than a 4670K and a not-Asrock Z87 microATX board. Secondly, the 3570K is only roughly ~6% slower than the 4670K but draws like 10% less power under load, and usually overclocks better than the 4670K since it doesn't heat up quite as much.
So far the only downside to siding the 3570K I've come across is that the 4670K system draws like 10W less idling, but I put my comp to sleep rather than just letting it sit on the desktop so I don't see this as a huge deal and think drawing less power under load will save me more (even though it's not a substantial amount either way).
So yeah, bottom line - any real reason to drop the extra $30 into the 4670K? With the money saved by grabbing the 3570K I can also grab the 212 Evo :p
ps. I'd grab the 2500K just for the sweet overclocking gains since it can surpass the 3570K pretty easily (apparently it's not even remotely uncommon to get 4.8-5GHz with the 2500K on air)... but retail they cost just as much or more than the 3570K (though now and then the 2550K drops below the 3570K) and I'd be worried about lifespan if I'm buying used, since I don't plan to upgrade the CPU any time soon.
hmm ill look into it more, but the <10% performance dif isn't a huge selling point to me when it seems it usually OCs a bit less than IVB and draw more power under load anyways. _shrug
CPUs don't overclock the same. You might overclock Ivybridge to the magical 5GHz point, or you might only achieve 4.2 on Ivy.
While Ivybridge can overclock further than Haswell, Haswell's performance could be seen as extra insurance against a poor overclocking achievement.
The last thing that you should be doing is considering the amount of overclocking that you can do. Haswell is much more feature packed, with 6GB sata across the Z87 platform. More power saving options. New instruction sets. Better utilities and just a generally up-to-date socket. And you want to throw all of that away to achieve a higher clock speed?
And my Haswell i7 overclocks to 4.6 without issue. I could probably overclock it to 4.7, but I keep it at a reasonable 4.2 for longevity. The largest CPU gains are probably up to that point, as anything after 4.2 is a pretty minuscule gain.
Id go the haswell. 4670k's are a nice chip. Add to that the current lineup of great matx boards available for the platform.
If you plan to oc then dont concern yourself with power consumption, as soon as you start increasing voltage the game changes.
Id probably save a little cash - grab a non-k 4670 or therabouts and put more money into a better gpu of high frequency memory as haswell's really like high speed ram. You can still oc the blck of a non-k chip anyways for a bit of fun.
I don't really have any need for more than a single SATA III/6Gbps port since even the fastest 7200RPM drives don't saturate the 3Gbps limit of SATA II (hell, most probably don't saturate SATA 1.5Gbps). Only plan to have a single SSD... eventually, won't even be getting that for a few months :p
And you're right, the silicon lottery isn't the best thing to base a purchasing decision on. Seemed logical to look at it the way I was, but there is that chance of getting a 3570K that won't pass 4.2GHz, and it's possible I'd get a 4670K that hits 4.8GHz.
I am interested in power savings, but from what I could tell from reviews (which I know aren't 100% accurate since they take averages and do only repeatable tasks, so it doesn't represent the grey area of day-to-day use) while a Haswell chip setup would save ~10W on idle over the ivy setup, it drew about 10W more under load. Not sure how that translates in light loads and surfing and stuff, but it seems like it'd even out either way since I tend to sleep my computer when I'm not gaming or working on it.
I doubt I personally need any of the features exclusive to the Z87 chipset, I don't really use any advanced features since I'm basically just casually gaming. But I'm not familiar with everything it has to offer. I'll do some more research, but I don't think the <10% IPC improvement is enough to sway me to sink the extra $30 or so for the Haswell chip when I could buy the 212 Evo to keep everything nice and cool... I probably won't even be overclocking right away - waiting until I actually need to; my Q6600 often caps me between 40-55 fps in many of my games so I expect the 3570K to be fine at stock for quite some time for me since it's nearly three times as fast).
What are the impact of the updated instruction sets?
Well I already have the GPU that I'll be continuing to use for some time.
Here just because of how the prices are it's still cheaper to get a 3570K and Z77 board over a 4670 non-K and Z87 board (about equal for H87 though). RAM speed isn't really a cost issue, 1866 and 2133 RAM cost within $5 of 1600 RAM (though I've yet to find any sources that show memory speed making a meaningful difference in gaming).
My objective is to buy a chip that will last me a long time without having to purchase a new one, so that's why I'd like one with unlocked multiplier so when the time comes that I'd need to upgrade the CPU otherwise, I can squeeze out some more juice instead.
As for power consumption when OCing, I don't know how accurate this article is (I need to find more comparing these same 3 processors) but it shows at stock the 2500K draws more than 4670K which draws more than 3570K (under load), and overclocked to 4.5GHz the 4670K draws more than the 3570K which draws more than the 2500K. Did Sandy Bridge OC more with less voltage change or something?
Thanks for your input, sorry if it seems I'm being stubborn.. I'm cheap and I need to find a good reason to spend the extra $30 for the 4670K XD just doesn't seem to offer anything too useful for my needs over 3570K platform
Well if overclocking is a main decision, it does not make much sense what ever you choose, because for a decent overclock you also wanne get a decent and stable motherboard. that is more important.. i would personaly go for haswell because i would personaly not invest in a dead platform anymore, but thats personal.
I5-4670K with Asus Gryphon for example is a nice combination. for overclocking.
The amount of money your talking about spending on these i5's and Z-series motherboards, why is $30 an issue? I'm sure you can find a Z87 mb that would cost close to or the same as what ever Z77 mb you have in mind and the Haswell platform will give you more features/bang for your buck. You say you don't need/want those extra features but you might in the future. Things change. People change their plans.
IMO it's worth it to go Haswell simply because it's really not more expensive and it's the latest technology (from Intel). I really don't get the logic behind going for older tech and not really saving anything. ($30 isn't much at this price point).
As others have said, if you're overclocking, why worry about power consumption? Most modern CPU's (AMD and Intel) use very little power at idle and while performing basic tasks. The differences are not really worth mentioning.
@deejeta, you can't OC a non-K haswell CPU. However, they dynamically OC on their own, which is pretty cool. I have the i5-4570 (which is a hair faster than the 3570/k and costs $30-40 less than the 3570/4670/k) which is 3.2ghz base and [supposedly] turbos to 3.6. I've seen it on several occasions bump itself up to almost 3.8 on all 4 cores.
Either way is a dead platform for me since I won't be upgrading for a few years anyhow, and Intel uses a new socket like every 2 years. Here the way the costs are, the microATX Z87 boards are really expensive for some reason. The full ATX mobos are the same between Z77 and Z87, but I can get the Asus P8Z77-m (it seems Asus and Gigabyte are the most reliable mobo ones, it looks like MSI and Asrock have questionable support but I'm not 100% sure). The cheapest Z87 mATX mobo is a couple bucks more but it's a cheap Asrock one. Asus and Gigabyte ones are at least $30 more. I'll research on the P8Z77 more but from the reviews (aside from DOA reviews) it sounds like it's decent. I'm not an insane overclocker and it's not like I'm going to be going for a 5GHz overclock lol ^^ don't care to spend an extra $80 to get an extra 200MHz out of it :p
I'm just trying to get the absolute most bang for my buck while going the microATX route
What extra features of note do they offer? From what I could find (haven't entirely scoured the internet yet, this is just a quick search) it looks like Z87 vs Z77 just offers more power saving features, more SATA 6Gbps, and native support for 1600MHz memory (which to the best of my understanding doesn't really change anything since I could just enter the timings manually anyways).
I don't need more than 1 SATA III port tbh, I don't even have an SSD at this point though I do plan to grab a Mushkin Chronos or something. After that point I'd only be using my 7200RPM drive w/ my games and WD Caviar Green for everything else.
To me the $30 makes a difference (not a gamechanger, but it does matter) since I've been saving for awhile for the upgrade and still need to save for a month or two. Being able to get the 212 EVO for the same price up front as getting the Z87 platform and being stuck with the stock intel heatsink is a nice bonus for me :p
So seems everyone suggests 4670K. Not sure if we just have different opinions and I'm not as much of an enthusiast or I just don't understand all the pluses of getting a 4670K. I'll keep an eye on the prices and look up more indepth the features of the Z87
well an i5-3570K is still a great cpu, So its not a bad choice, if you can find a decent board for cheaper.
Only im personaly like i said would not invest in a dead socket anymore, but if you totaly don´t care about that. Then the i5-3570K with a cheaper decent motherboard is a great choice realy. ☺
I'm just merely stating my opinion/preferences, considering the facts. I'd rather spend the extra $30 now and know that I have those few extra options/features should I choose to use them in the future (if I change my mind) and use the stock cooler until I can scrape up another $30. But like I said before, you can probably find a comparable Z87 board that costs the same as the Z77 board you have in mind. Which Z77 board were you thinking of using?
The stock Intel cooler is not horrible, especially if you use some good aftermarket thermal compound. But I wouldn't do much overclocking with it though. :P
I was in a similar predicament. I wanted an ITX system, and was really short on the budget. Seeing that Haswell was only a ~7% performance increase on the desktop side, and I'm not any extreme overclocker (still wanted a z77/z87 chipset, though), I went with Ivy due to a ~$40 price difference at the time(ivyK + z77 vs haswellK + z87). If the price difference is 10-20 bucks, I'd say go haswell because it's newer silicon. Any higher and I would opt for Ivy.
The two Z77 boards I'm interested in are the Asus P8Z77-M and the MSI Z77MA-G45. They're both $120 standard price. The cheapest Z87 boards besides cheapo Asrock ones which I'd like to avoid (judging from the reviews sections their support doesn't seem to be as good as Asus, Gigabyte and MSI) are the GA-Z87MX-D3H at about $140 standard, next one up from that is the Asus Z87M-PLUS at $145, then MSI Z87 gaming at like $170.
I'll look up some more info on the P8Z77-M and Z77MA-G45 and GA-Z87MX-D3H and see how they fare.
You're missing out on the key features of haswell anyway if you get a K series i5/i7.
You can overclock non-k, I have a 4770 @ 4.3 Ghz stable using only bclk strap.
Haswell is actually more worth the difference in the long run. The power saving features will pay those 30$ off in a matter of 1-2 years, and for better IPC performance it's a better deal.
I too don't find the point of buying older hardware new from shops. It would make sense if on a budget you need the best top of the line second hand from a few generations back that would keep up with a more expensive part today but really, when buying a new computer, always invest in the latest and greatest that you can afford. Spend as much on your PC as you can justify, it will speed up everything you do until your next upgrade.
