Haswell Upgrade
Hi guys,
I'm planning to upgrade my current PC to a new Haswell i5. This will also involve upgrading my Mobo and PSU for compatibility reasons.
My current specs are as follows:
  • AMD Phenom II 840 @ 3.2GHz
  • Gigabyte ga-m68mt-s2 motherboard
  • 8GB Exceleram Black Sark Series (2x4GB) DDR3 1600MHz Dual Channel Kit
  • MSI GTX560ti
  • Coolermaster Elite 430 case
  • 2 x HDDs
  • 550w Coolermaster PSU
I want to upgrade for a performance boost in games and development, as well as just wanting to bring PC a little more up to date. I play a wide variety of games, some of which are the more demanding games such as BF3 and Skyrim and upcoming games like watchdogs and GTV V (hopefully..!). I am not bothered about running them maxed out but do like to play games at 60fps. The development I do is mainly web development but my studies are likely to involve other types also so I'd like to be ready for that.
I've gone with the i5 after reading that the i7 offers few performance gains for the money, and I am hoping to save money where possible but not on a strict budget of sorts. I'm in the UK and expecting to spend between £400 and £450, don't want to go higher than that.
The parts I'm looking at are the following:
Are these a good selection of parts? From what I can see they're all compatible and the motherboard seemed like it might be fairly future-proof in terms of expansion (the possibility of SLI and 2+ slots of RAM). Can I do better for the price?
Thanks.
The northbridge chipset on your motherboard does not allow for overclocking.  You need a z87 chipset for haswell.
I'd personally stick with Ivy Bridge.  Haswell has minimal performance increases for the desktop, being hotter and with better igpu(useless unless for some mini htpc).  Save some money and get a i5 3570k and a lga1155 motherboard with a z77 chipset.
Your power supply should be sufficient, but Cooler Master's PSU series really vary.  It'd be nice to find the series as I know the eXtreme Power Plus series is basically, junk.
