Now that Haswell is officially out I'm looking to do a build. Did a quick check on the forums for Haswell mobos but didn't find what i'm looking for. I'd like recommendations on a good Haswell compatible mobo in the $150 range. Will be pairing it with the i5 4670k and want to OC it.
Thanks for the replies. To ask a total noob question, what's the problem with ASUS going with gold? The ASUS Z87-A SLI found here: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8139496&CatId=8586 looks as good as the MSI board and it's cheaper.
To answer your question about the gold it just looks ridiculous, like driving a gold impala but if you like that go for it. Personally I am going with an Asus Gryphon for my matx build but I would suggest the ASRock Z87 Xterme4 it will be a good value like all ASRock boards and in my experience the all OC pretty well too.
