Hey Logan, I am currently working on a budget build for a friend of mine, and I was wondering if it is worth the wait until September 29th when the budget Haswell I3s and Pentiums launche in America, or if he should just go ivy now. Thanks in advance.
You should go AMD if you're creating a budget build. Could you link me your parts for now and tell me the budget?
