Im going to buy the i7 5820k
Im currently running the hyper 212 from coolermaster. Will this be compatible with this socket?
If not, what do you guys think will a good cooling option?
thanks
thanks
If you still have the 2011 mounting hardware , yes.
But I would recommend a nh-d15 or something like that ( h100i or similar ) because they put out about ~1.8x more heat than a i7 4770k .
ok sure. ill pick one up. i might put this on ebay tonight then
