Haswell build for under 800€
I was thinking if there is a possibility to build a new intel 4 gen processor gaming computer for under 800 €. I tried to put up a list of my own but i don't know if this thing will work out.It would be nice if it would have OC possibility and SSD(but its not necessery if it doesn't fit in the budget). I don't need any perepherals neither OS.
So here is the list :
Mobo:ASUS Z87-A 126€
Cpu: Intel i5 4670k 217€
Ram:Corsair Vengeance 35.50€
Case: Bitfenix Shinobi 50€
Cpu cooler: Cooler Master 212 EVO 32€
But my problem is that I don't know what HDD and PSU to take.
i know you have put euros but you didnt say where in europe, also i didn't know if you needed a GPU or not so i put one in anyway http://de.pcpartpicker.com/p/1fPkT
But you don't NEED Haswell, a 3570k will maybe suit you better because it's cheaper and the performance loss is not so big (around 10-15%)
if you need to stay strickt under €800 then i would recommend to go with AMD. if you can spend a little bit more, and you want to stay with hasswell. then i made this
http://tweakers.net/gallery/526243?wish_id=462153#tab:wenslijst
notice that prices are based on Dutch prices.!!!
you can allways buy an aftermarket cpu cooler and SSD later. and overclock after then.
grtz Angel ☺
Forgot to mention that I'm from Estonia and a gpu is necessery because of video editing and adobe after effects. I would really like to stay on Intel side because of their reliability. Also MisteryAngel prices in the Netherlands is really cheap compared to Estonia where the cheapest 760 is 245 €. Now about the GPU I think that 660 will satisfy my needs.
At mazdarati2 I would like to use especially this gen processors because of future proofnes.If a new gen processors come then it will be 1 gen old instead of 2 generations old.Also haswell chipset has IMO tons of improvments that are really great.
