I was going to buy the X-Stor and I noticed these are cheaper than those ones. Not sure how good they are- but it looks fairly similar to it.
Then I noticed that there is this monitor http://www.ebay.com/sch/i.html?_sacat=0&_from=R40&_nkw=M27QSM&_sop=15
it's $270 and looks to pretty much be the same panel...not quite sure though...
Anyone here have any opinions? ...I think I might get one...
Anyone here have any opinions on this...thing?
No experience with this make. If its the same panel as the Shimian its good.
also:
Local pickup only? you could look at it when you pick it up ey?
I noticed that afterwards and derped...
I think it has the same panel as the xstar (the shimian is LG? right?)
it's like...$1 cheaper...ehh
Dreamseller also has the fsm270-YG, which is pretty much a cheaper x-star with bigger speakers- http://www.ebay.com/itm/First-FSM-270YG-LED-LG-S-IPS-16-9-WIDE-2560x1440-WQHD-27-MONITOR-/320933726714?pt=Computer_Monitors&hash=item4ab92409fa
But at the same time, it says the x-star panel is Samsung-IPS ad the FSM is S-IPS (not sure if same thing)
