[73133.839901] vfio-pci 0000:85:00.0: Navi10: performing BACO reset
[73163.594091] vfio-pci 0000:85:00.0: enabling device (0400 -> 0403)
[73163.595229] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x19@0x270
[73163.595897] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x1b@0x2d0
[73163.596576] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x25@0x400
[73163.597260] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x26@0x410
[73163.597952] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x27@0x440
[73163.710753] vfio-pci 0000:00:1d.0: vfio_cap_init: hiding cap 0xa@0x58
[73163.823180] vfio-pci 0000:00:1a.0: vfio_cap_init: hiding cap 0xa@0x58
[73616.404964] vfio-pci 0000:85:00.0: Navi10: performing BACO reset
[73616.407861] vfio-pci 0000:85:00.0: Navi10: SMU error 0xff (line 4035)
[73617.401977] vfio-pci 0000:85:00.0: Navi10: sol register = 0x273a58a
[73622.180087] vfio-pci 0000:85:00.0: Navi10: performing BACO reset
[73622.183193] vfio-pci 0000:85:00.0: Navi10: SMU error 0xff (line 4035)
[73623.177322] vfio-pci 0000:85:00.0: Navi10: sol register = 0x273a9d6
[73632.434152] vfio-pci 0000:85:00.0: enabling device (0400 -> 0403)
[73632.434991] vfio-pci 0000:85:00.0: Navi10: performing BACO reset
[73632.437518] vfio-pci 0000:85:00.0: Navi10: SMU error 0xff (line 4035)
[73633.431446] vfio-pci 0000:85:00.0: Navi10: sol register = 0x273b0d5
[73633.432319] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x19@0x270
[73633.432798] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x1b@0x2d0
[73633.433278] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x25@0x400
[73633.433754] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x26@0x410
[73633.434171] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x27@0x440
[73633.437620] vfio-pci 0000:00:1d.0: enabling device (0000 -> 0002)
[73633.544073] vfio-pci 0000:00:1d.0: vfio_cap_init: hiding cap 0xa@0x58
[73633.545836] vfio-pci 0000:00:1a.0: enabling device (0000 -> 0002)
[73633.654726] vfio-pci 0000:00:1a.0: vfio_cap_init: hiding cap 0xa@0x58
[73634.032087] vfio-pci 0000:85:00.0: Navi10: performing BACO reset
[73634.034832] vfio-pci 0000:85:00.0: Navi10: SMU error 0xff (line 4035)
[73635.028840] vfio-pci 0000:85:00.0: Navi10: sol register = 0x273b21b
[73715.200151] vfio-pci 0000:85:00.0: Navi10: performing BACO reset
[73716.193839] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4023)
[73717.187419] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4029)
[73718.181081] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4035)
[73720.167199] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4043)
[73720.167906] vfio-pci 0000:85:00.0: Navi10: sol register = 0x275213b
[73720.187910] vfio-pci 0000:85:00.0: Refused to change power state, currently in D0
[73729.326760] vfio-pci 0000:85:00.0: Navi10: performing BACO reset
[73730.320415] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4023)
[73731.314002] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4029)
[73732.307584] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4035)
[73734.293668] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4043)
[73734.294399] vfio-pci 0000:85:00.0: Navi10: sol register = 0x2752afc
[73743.359587] vfio-pci 0000:85:00.0: enabling device (0400 -> 0403)
[73743.360430] vfio-pci 0000:85:00.0: Navi10: performing BACO reset
[73744.353840] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4023)
[73745.347506] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4029)
[73746.341296] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4035)
[73748.327343] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4043)
[73748.328114] vfio-pci 0000:85:00.0: Navi10: sol register = 0x27534ae
[73748.328809] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x19@0x270
[73748.329341] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x1b@0x2d0
[73748.329800] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x25@0x400
[73748.330241] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x26@0x410
[73748.330667] vfio-pci 0000:85:00.0: vfio_ecap_init: hiding ecap 0x27@0x440
[73748.334174] vfio-pci 0000:00:1d.0: enabling device (0000 -> 0002)
[73748.439867] vfio-pci 0000:00:1d.0: vfio_cap_init: hiding cap 0xa@0x58
[73748.441766] vfio-pci 0000:00:1a.0: enabling device (0000 -> 0002)
[73748.550740] vfio-pci 0000:00:1a.0: vfio_cap_init: hiding cap 0xa@0x58
[73748.927929] vfio-pci 0000:85:00.0: Navi10: performing BACO reset
[73749.921624] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4023)
[73750.915315] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4029)
[73751.908936] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4035)
[73753.894977] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4043)
[73753.895692] vfio-pci 0000:85:00.0: Navi10: sol register = 0x2753879
[74232.876197] vfio-pci 0000:85:00.0: Navi10: performing BACO reset
[74233.869969] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4023)
[74234.863959] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4029)
[74235.857853] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4035)
[74237.844390] vfio-pci 0000:85:00.0: Navi10: SMU error 0x0 (line 4043)
[74237.844981] vfio-pci 0000:85:00.0: Navi10: sol register = 0x277e845
[74237.862778] vfio-pci 0000:85:00.0: Refused to change power state, currently in D0
These are the errors on the host I am getting ONLY with a Linux guest. If I reboot, I can get a login screen on an Ubuntu guest once, and when I try and log in x crashes and I’m set back to the log in screen. I should also add, I can reboot a windows guest as much as I want, but I use a linux guest, shutdown then boot into windows, or reboot into the Linux guest again, I get the above errors. Seems like the reset bug? The below logs are after a reboot and first boot into a Linux guest. The errors are the same for Ubuntu and manjaro.
Guest logs after a reboot and not getting the above errors:
lspci -vv
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] (rev c1) (prog-if 00 [VGA controller])
Subsystem: XFX Pine Group Inc. Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
Physical Slot: 0
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 34
Region 0: Memory at 1000000000 (64-bit, prefetchable) [size=256M]
Region 2: Memory at 1010000000 (64-bit, prefetchable) [size=2M]
Region 4: I/O ports at d000 [size=256]
Region 5: Memory at c2000000 (32-bit, non-prefetchable) [size=512K]
Expansion ROM at c2080000 [disabled] [size=512K]
Capabilities: [48] Vendor Specific Information: Len=08 <?>
Capabilities: [50] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [64] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <4us, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd- ExtTag+ PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 16GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 16GT/s (ok), Width x16 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, NROPrPrP-, LTR+
10BitTagComp+, 10BitTagReq+, OBFF Not Supported, ExtFmt+, EETLPPrefix+, MaxEETLPPrefixes 1
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS-
AtomicOpsCap: 32bit+ 64bit+ 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
AtomicOpsCtl: ReqEn-
LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee09000 Data: 4022
Capabilities: [100 v1] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [150 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [240 v1] Power Budgeting <?>
Capabilities: [2a0 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [2b0 v1] Address Translation Service (ATS)
ATSCap: Invalidate Queue Depth: 00
ATSCtl: Enable+, Smallest Translation Unit: 00
Capabilities: [2c0 v1] Page Request Interface (PRI)
PRICtl: Enable- Reset-
PRISta: RF- UPRGI- Stopped+
Page Request Capacity: 00000100, Page Request Allocation: 00000000
Capabilities: [320 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Kernel driver in use: amdgpu
Kernel modules: amdgpu
dmesg | grep amdgpu
[ 2.327902] [drm] amdgpu kernel modesetting enabled.
[ 2.328304] amdgpu 0000:01:00.0: remove_conflicting_pci_framebuffers: bar 0: 0x1000000000 -> 0x100fffffff
[ 2.328306] amdgpu 0000:01:00.0: remove_conflicting_pci_framebuffers: bar 2: 0x1010000000 -> 0x10101fffff
[ 2.328307] amdgpu 0000:01:00.0: remove_conflicting_pci_framebuffers: bar 5: 0xc2000000 -> 0xc207ffff
[ 2.345363] amdgpu 0000:01:00.0: VRAM: 8176M 0x0000008000000000 - 0x00000081FEFFFFFF (8176M used)
[ 2.345364] amdgpu 0000:01:00.0: GART: 512M 0x0000000000000000 - 0x000000001FFFFFFF
[ 2.345413] [drm] amdgpu: 8176M of VRAM memory ready
[ 2.345418] [drm] amdgpu: 8176M of GTT memory ready.
[ 3.110267] amdgpu: [powerplay] smu driver if version = 0x00000033, smu fw if version = 0x00000035, smu fw version = 0x002a3200 (42.50.0)
[ 3.110268] amdgpu: [powerplay] SMU driver if version not matched
[ 3.122485] amdgpu: [powerplay] SMU is initialized successfully!
[ 3.297911] amdgpu 0000:01:00.0: fb1: amdgpudrmfb frame buffer device
[ 3.298003] amdgpu 0000:01:00.0: ring 0(gfx_0.0.0) uses VM inv eng 4 on hub 0
[ 3.298004] amdgpu 0000:01:00.0: ring 1(gfx_0.1.0) uses VM inv eng 5 on hub 0
[ 3.298005] amdgpu 0000:01:00.0: ring 2(comp_1.0.0) uses VM inv eng 6 on hub 0
[ 3.298006] amdgpu 0000:01:00.0: ring 3(comp_1.1.0) uses VM inv eng 7 on hub 0
[ 3.298006] amdgpu 0000:01:00.0: ring 4(comp_1.2.0) uses VM inv eng 8 on hub 0
[ 3.298007] amdgpu 0000:01:00.0: ring 5(comp_1.3.0) uses VM inv eng 9 on hub 0
[ 3.298008] amdgpu 0000:01:00.0: ring 6(comp_1.0.1) uses VM inv eng 10 on hub 0
[ 3.298009] amdgpu 0000:01:00.0: ring 7(comp_1.1.1) uses VM inv eng 11 on hub 0
[ 3.298009] amdgpu 0000:01:00.0: ring 8(comp_1.2.1) uses VM inv eng 12 on hub 0
[ 3.298010] amdgpu 0000:01:00.0: ring 9(comp_1.3.1) uses VM inv eng 13 on hub 0
[ 3.298011] amdgpu 0000:01:00.0: ring 10(kiq_2.1.0) uses VM inv eng 14 on hub 0
[ 3.298012] amdgpu 0000:01:00.0: ring 11(sdma0) uses VM inv eng 15 on hub 0
[ 3.298012] amdgpu 0000:01:00.0: ring 12(sdma1) uses VM inv eng 16 on hub 0
[ 3.298013] amdgpu 0000:01:00.0: ring 13(vcn_dec) uses VM inv eng 4 on hub 1
[ 3.298014] amdgpu 0000:01:00.0: ring 14(vcn_enc0) uses VM inv eng 5 on hub 1
[ 3.298015] amdgpu 0000:01:00.0: ring 15(vcn_enc1) uses VM inv eng 6 on hub 1
[ 3.298015] amdgpu 0000:01:00.0: ring 16(vcn_jpeg) uses VM inv eng 7 on hub 1
[ 3.298233] [drm] Initialized amdgpu 3.35.0 20150101 for 0000:01:00.0 on mino
cat /home/xxx/.local/share/xorg/Xorg.0.log
[ 3.991] (--) Log file renamed from "/home/xxx/.local/share/xorg/Xorg.pid-992.log" to "/home/xxx/.local/share/xorg/Xorg.0.log"
[ 3.992]
X.Org X Server 1.20.8
X Protocol Version 11, Revision 0
[ 3.992] Build Operating System: Linux 4.4.0-177-generic x86_64 Ubuntu
[ 3.992] Current Operating System: Linux xxx-virt 5.4.0-40-generic #44-Ubuntu SMP Tue Jun 23 00:01:04 UTC 2020 x86_64
[ 3.992] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4.0-40-generic root=UUID=afb2b810-b2f4-4687-bada-30deb952b343 ro quiet splash vt.handoff=7
[ 3.992] Build Date: 06 April 2020 09:39:29AM
[ 3.992] xorg-server 2:1.20.8-2ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[ 3.992] Current version of pixman: 0.38.4
[ 3.992] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 3.992] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 3.992] (==) Log file: "/home/xxx/.local/share/xorg/Xorg.0.log", Time: Sat Jul 18 11:16:49 2020
[ 3.993] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3.994] (==) No Layout section. Using the first Screen section.
[ 3.994] (==) No screen section available. Using defaults.
[ 3.994] (**) |-->Screen "Default Screen Section" (0)
[ 3.994] (**) | |-->Monitor "<default monitor>"
[ 3.995] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 3.995] (==) Automatically adding devices
[ 3.995] (==) Automatically enabling devices
[ 3.995] (==) Automatically adding GPU devices
[ 3.995] (==) Automatically binding GPU devices
[ 3.995] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3.998] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 3.998] Entry deleted from font path.
[ 3.998] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 3.998] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 3.999] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 3.999] Entry deleted from font path.
[ 3.999] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 3.999] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 3.999] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 3.999] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 3.999] (II) Loader magic: 0x5590fd15f020
[ 3.999] (II) Module ABI versions:
[ 3.999] X.Org ANSI C Emulation: 0.4
[ 3.999] X.Org Video Driver: 24.1
[ 3.999] X.Org XInput driver : 24.1
[ 3.999] X.Org Server Extension : 10.0
[ 4.000] (++) using VT number 2
[ 4.001] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 4.002] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 4.002] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[ 4.002] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 4.003] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 13 paused 0
[ 4.007] (--) PCI:*(0@0:1:0) 1234:1111:1af4:1100 rev 2, Mem @ 0xc0000000/16777216, 0xc228b000/4096, BIOS @ 0x????????/131072
[ 4.007] (--) PCI: (1@0:0:0) 1002:731f:1682:5701 rev 193, Mem @ 0x1000000000/268435456, 0x1010000000/2097152, 0xc2000000/524288, I/O @ 0x0000d000/256, BIOS @ 0x????????/524288
[ 4.007] (II) LoadModule: "glx"
[ 4.008] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 4.016] (II) Module glx: vendor="X.Org Foundation"
[ 4.016] compiled for 1.20.8, module version = 1.0.0
[ 4.016] ABI class: X.Org Server Extension, version 10.0
[ 4.016] (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
[ 4.016] loading driver: amdgpu
[ 4.016] (==) Matched amdgpu as autoconfigured driver 0
[ 4.016] (==) Matched ati as autoconfigured driver 1
[ 4.016] (==) Matched modesetting as autoconfigured driver 2
[ 4.016] (==) Matched fbdev as autoconfigured driver 3
[ 4.016] (==) Matched vesa as autoconfigured driver 4
[ 4.016] (==) Assigned the driver to the xf86ConfigLayout
[ 4.016] (II) LoadModule: "amdgpu"
[ 4.017] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 4.020] (II) Module amdgpu: vendor="X.Org Foundation"
[ 4.020] compiled for 1.20.5, module version = 19.1.0
[ 4.020] Module class: X.Org Video Driver
[ 4.020] ABI class: X.Org Video Driver, version 24.0
[ 4.020] (II) LoadModule: "ati"
[ 4.021] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 4.021] (II) Module ati: vendor="X.Org Foundation"
[ 4.021] compiled for 1.20.5, module version = 19.1.0
[ 4.021] Module class: X.Org Video Driver
[ 4.021] ABI class: X.Org Video Driver, version 24.0
[ 4.021] (II) LoadModule: "modesetting"
[ 4.021] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 4.023] (II) Module modesetting: vendor="X.Org Foundation"
[ 4.023] compiled for 1.20.8, module version = 1.20.8
[ 4.023] Module class: X.Org Video Driver
[ 4.023] ABI class: X.Org Video Driver, version 24.1
[ 4.023] (II) LoadModule: "fbdev"
[ 4.023] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 4.023] (II) Module fbdev: vendor="X.Org Foundation"
[ 4.023] compiled for 1.20.1, module version = 0.5.0
[ 4.023] ABI class: X.Org Video Driver, version 24.0
[ 4.023] (II) LoadModule: "vesa"
[ 4.024] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 4.024] (II) Module vesa: vendor="X.Org Foundation"
[ 4.024] compiled for 1.20.4, module version = 2.4.0
[ 4.024] Module class: X.Org Video Driver
[ 4.024] ABI class: X.Org Video Driver, version 24.0
[ 4.024] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 4.024] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 4.024] (II) FBDEV: driver for framebuffer: fbdev
[ 4.024] (II) VESA: driver for VESA chipsets: vesa
[ 4.024] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[ 4.025] (II) modeset(0): using drv /dev/dri/card0
[ 4.025] (WW) Falling back to old probe method for fbdev
[ 4.025] (II) Loading sub module "fbdevhw"
[ 4.025] (II) LoadModule: "fbdevhw"
[ 4.025] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 4.025] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 4.025] compiled for 1.20.8, module version = 0.0.2
[ 4.025] ABI class: X.Org Video Driver, version 24.1
[ 4.025] (EE) open /dev/fb0: Permission denied
[ 4.026] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 4.026] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 4.026] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 4.026] (==) modeset(0): RGB weight 888
[ 4.026] (==) modeset(0): Default visual is TrueColor
[ 4.026] (II) Loading sub module "glamoregl"
[ 4.026] (II) LoadModule: "glamoregl"
[ 4.026] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 4.033] (II) Module glamoregl: vendor="X.Org Foundation"
[ 4.033] compiled for 1.20.8, module version = 1.0.1
[ 4.033] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.219] (II) modeset(0): Refusing to try glamor on llvmpipe
[ 4.221] (EE) modeset(0): glamor initialization failed
[ 4.221] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[ 4.221] (II) modeset(0): Output Virtual-1 has no monitor section
[ 4.221] (II) modeset(0): EDID for output Virtual-1
[ 4.221] (II) modeset(0): Manufacturer: RHT Model: 1234 Serial#: 0
[ 4.221] (II) modeset(0): Year: 2014 Week: 42
[ 4.221] (II) modeset(0): EDID Version: 1.4
[ 4.221] (II) modeset(0): Digital Display Input
[ 4.221] (II) modeset(0): 8 bits per channel
[ 4.221] (II) modeset(0): Digital interface is DisplayPort
[ 4.221] (II) modeset(0): Max Image Size [cm]: horiz.: 26 vert.: 19
[ 4.221] (II) modeset(0): Gamma: 2.20
[ 4.221] (II) modeset(0): No DPMS capabilities specified
[ 4.221] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 4.221] (II) modeset(0): Default color space is primary color space
[ 4.221] (II) modeset(0): First detailed timing is preferred mode
[ 4.221] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 4.222] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 4.222] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329
[ 4.222] (II) modeset(0): Supported established timings:
[ 4.222] (II) modeset(0): 640x480@60Hz
[ 4.222] (II) modeset(0): 800x600@60Hz
[ 4.222] (II) modeset(0): 1024x768@60Hz
[ 4.222] (II) modeset(0): Manufacturer's mask: 0
[ 4.222] (II) modeset(0): Supported standard timings:
[ 4.222] (II) modeset(0): #0: hsize: 2048 vsize 1152 refresh: 60 vid: 49377
[ 4.222] (II) modeset(0): #1: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 4.222] (II) modeset(0): Supported detailed timing:
[ 4.222] (II) modeset(0): clock: 82.3 MHz Image Size: 403 x 302 mm
[ 4.222] (II) modeset(0): h_active: 1024 h_sync: 1280 h_sync_end 1310 h_blank_end 1382 h_border: 0
[ 4.222] (II) modeset(0): v_active: 768 v_sync: 771 v_sync_end 774 v_blanking: 794 v_border: 0
[ 4.222] (II) modeset(0): Ranges: V min: 50 V max: 125 Hz, H min: 30 H max: 160 kHz, PixClock max 1205 MHz
[ 4.222] (II) modeset(0): Monitor name: QEMU Monitor
[ 4.222] (II) modeset(0): Established timings III: (not decoded)
[ 4.222] (II) modeset(0): Number of EDID sections to follow: 1
[ 4.222] (II) modeset(0): EDID (in hex):
[ 4.222] (II) modeset(0): 00ffffffffffff004914341200000000
[ 4.222] (II) modeset(0): 2a180104a51a137806ee91a3544c9926
[ 4.222] (II) modeset(0): 0f5054210800e1c0d1c0010101010101
[ 4.222] (II) modeset(0): 0101010101012520006641001a30001e
[ 4.222] (II) modeset(0): 3340932e11000018000000fd00327d1e
[ 4.222] (II) modeset(0): a078010a202020202020000000fc0051
[ 4.222] (II) modeset(0): 454d55204d6f6e69746f720a000000f7
[ 4.222] (II) modeset(0): 000a004aa22429200000000000000132
[ 4.222] (II) modeset(0): 02030a00457d6560591f000000000000
[ 4.222] (II) modeset(0): 00000000000000000000000000000000
[ 4.222] (II) modeset(0): 000000000000000000000000000000f2
[ 4.222] (II) modeset(0): Printing probed modes for output Virtual-1
[ 4.222] (II) modeset(0): Modeline "1024x768"x75.0 82.29 1024 1280 1310 1382 768 771 774 794 -hsync -vsync (59.5 kHz eP)
[ 4.222] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 -hsync -vsync (67.5 kHz e)
[ 4.222] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 4.222] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 4.222] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 4.222] (II) modeset(0): Modeline "1400x1050"x60.0 121.75 1400 1488 1632 1864 1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[ 4.222] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 4.222] (II) modeset(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 4.222] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 4.222] (II) modeset(0): Modeline "1360x768"x60.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[ 4.222] (II) modeset(0): Modeline "1280x768"x59.9 79.50 1280 1344 1472 1664 768 771 778 798 -hsync +vsync (47.8 kHz e)
[ 4.222] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 4.222] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 4.222] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 4.222] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 4.222] (II) modeset(0): Output Virtual-1 connected
[ 4.222] (II) modeset(0): Using exact sizes for initial modes
[ 4.222] (II) modeset(0): Output Virtual-1 using initial mode 1024x768 +0+0
[ 4.222] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 4.222] (==) modeset(0): DPI set to (96, 96)
[ 4.222] (II) Loading sub module "fb"
[ 4.222] (II) LoadModule: "fb"
[ 4.222] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 4.224] (II) Module fb: vendor="X.Org Foundation"
[ 4.224] compiled for 1.20.8, module version = 1.0.0
[ 4.224] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.224] (==) AMDGPU(G0): Depth 24, (--) framebuffer bpp 32
[ 4.224] (II) AMDGPU(G0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 4.224] (==) AMDGPU(G0): Default visual is TrueColor
[ 4.224] (==) AMDGPU(G0): RGB weight 888
[ 4.224] (II) AMDGPU(G0): Using 8 bits per RGB (8 bit DAC)
[ 4.224] (--) AMDGPU(G0): Chipset: "AMD Radeon RX 5700 XT" (ChipID = 0x731f)
[ 4.224] (II) Loading sub module "fb"
[ 4.224] (II) LoadModule: "fb"
[ 4.224] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 4.224] (II) Loading sub module "dri2"
[ 4.224] (II) LoadModule: "dri2"
[ 4.224] (II) Module "dri2" already built-in
[ 4.277] (II) Loading sub module "glamoregl"
[ 4.277] (II) LoadModule: "glamoregl"
[ 4.277] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 4.277] (II) Module glamoregl: vendor="X.Org Foundation"
[ 4.277] compiled for 1.20.8, module version = 1.0.1
[ 4.277] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.296] (II) AMDGPU(G0): glamor X acceleration enabled on AMD Radeon RX 5700 XT (NAVI10, DRM 3.35.0, 5.4.0-40-generic, LLVM 9.0.1)
[ 4.296] (II) AMDGPU(G0): glamor detected, initialising EGL layer.
[ 4.296] (==) AMDGPU(G0): TearFree property default: auto
[ 4.296] (II) AMDGPU(G0): Output DisplayPort-1-0 has no monitor section
[ 4.296] (II) AMDGPU(G0): Output DisplayPort-1-1 has no monitor section
[ 4.297] (II) AMDGPU(G0): Output DisplayPort-1-2 has no monitor section
[ 4.297] (II) AMDGPU(G0): Output HDMI-A-1-0 has no monitor section
[ 4.316] (II) AMDGPU(G0): EDID for output DisplayPort-1-0
[ 4.317] (II) AMDGPU(G0): EDID for output DisplayPort-1-1
[ 4.317] (II) AMDGPU(G0): Manufacturer: ACI Model: 23f7 Serial#: 63045
[ 4.317] (II) AMDGPU(G0): Year: 2010 Week: 42
[ 4.317] (II) AMDGPU(G0): EDID Version: 1.4
[ 4.317] (II) AMDGPU(G0): Digital Display Input
[ 4.317] (II) AMDGPU(G0): 8 bits per channel
[ 4.317] (II) AMDGPU(G0): Digital interface is DisplayPort
[ 4.317] (II) AMDGPU(G0): Max Image Size [cm]: horiz.: 51 vert.: 29
[ 4.317] (II) AMDGPU(G0): Gamma: 2.20
[ 4.317] (II) AMDGPU(G0): DPMS capabilities: Off
[ 4.317] (II) AMDGPU(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 4.317] (II) AMDGPU(G0): First detailed timing is preferred mode
[ 4.317] (II) AMDGPU(G0): Preferred mode is native pixel format and refresh rate
[ 4.317] (II) AMDGPU(G0): redX: 0.644 redY: 0.336 greenX: 0.295 greenY: 0.614
[ 4.317] (II) AMDGPU(G0): blueX: 0.146 blueY: 0.072 whiteX: 0.313 whiteY: 0.329
[ 4.317] (II) AMDGPU(G0): Supported established timings:
[ 4.317] (II) AMDGPU(G0): 720x400@70Hz
[ 4.317] (II) AMDGPU(G0): 640x480@60Hz
[ 4.317] (II) AMDGPU(G0): 640x480@67Hz
[ 4.317] (II) AMDGPU(G0): 640x480@75Hz
[ 4.317] (II) AMDGPU(G0): 800x600@56Hz
[ 4.317] (II) AMDGPU(G0): 800x600@60Hz
[ 4.317] (II) AMDGPU(G0): 800x600@72Hz
[ 4.317] (II) AMDGPU(G0): 800x600@75Hz
[ 4.317] (II) AMDGPU(G0): 832x624@75Hz
[ 4.317] (II) AMDGPU(G0): 1024x768@60Hz
[ 4.317] (II) AMDGPU(G0): 1024x768@70Hz
[ 4.317] (II) AMDGPU(G0): 1024x768@75Hz
[ 4.317] (II) AMDGPU(G0): 1280x1024@75Hz
[ 4.317] (II) AMDGPU(G0): Manufacturer's mask: 0
[ 4.317] (II) AMDGPU(G0): Supported standard timings:
[ 4.317] (II) AMDGPU(G0): #0: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 4.317] (II) AMDGPU(G0): #1: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 4.317] (II) AMDGPU(G0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 4.317] (II) AMDGPU(G0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 4.317] (II) AMDGPU(G0): #4: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 4.317] (II) AMDGPU(G0): Supported detailed timing:
[ 4.317] (II) AMDGPU(G0): clock: 148.5 MHz Image Size: 509 x 286 mm
[ 4.317] (II) AMDGPU(G0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 4.317] (II) AMDGPU(G0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 4.317] (II) AMDGPU(G0): Ranges: V min: 50 V max: 122 Hz, H min: 24 H max: 140 kHz, PixClock max 295 MHz
[ 4.317] (II) AMDGPU(G0): Monitor name: ASUS VG236
[ 4.317] (II) AMDGPU(G0): Serial No: AALMTF063045
[ 4.317] (II) AMDGPU(G0): clock: 235.5 MHz Image Size: 509 x 286 mm
[ 4.317] (II) AMDGPU(G0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 4.317] (II) AMDGPU(G0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1133 v_border: 0
[ 4.317] (II) AMDGPU(G0): clock: 260.2 MHz Image Size: 509 x 286 mm
[ 4.317] (II) AMDGPU(G0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1138 v_border: 0
[ 4.317] (II) AMDGPU(G0): clock: 285.5 MHz Image Size: 509 x 286 mm
[ 4.317] (II) AMDGPU(G0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1144 v_border: 0
[ 4.317] (II) AMDGPU(G0): Number of EDID sections to follow: 1
[ 4.317] (II) AMDGPU(G0): EDID (in hex):
[ 4.317] (II) AMDGPU(G0): 00ffffffffffff000469f72345f60000
[ 4.317] (II) AMDGPU(G0): 2a140104a5331d782ac965a4564b9d25
[ 4.317] (II) AMDGPU(G0): 125054b7ef0081c0814081809500b300
[ 4.317] (II) AMDGPU(G0): 010101010101023a801871382d40582c
[ 4.317] (II) AMDGPU(G0): 4500fd1e1100001e000000fd00327a18
[ 4.317] (II) AMDGPU(G0): 8c1d000a202020202020000000fc0041
[ 4.317] (II) AMDGPU(G0): 5355532056473233360a2020000000ff
[ 4.317] (II) AMDGPU(G0): 0041414c4d54463036333034350a018c
[ 4.317] (II) AMDGPU(G0): 02010400fe5b80a07038354030203500
[ 4.317] (II) AMDGPU(G0): fd1e1100001ea96580a070383a403020
[ 4.317] (II) AMDGPU(G0): 3500fd1e1100001e866f80a070384040
[ 4.317] (II) AMDGPU(G0): 30203500fd1e1100001e000000000000
[ 4.317] (II) AMDGPU(G0): 00000000000000000000000000000000
[ 4.317] (II) AMDGPU(G0): 00000000000000000000000000000069
[ 4.317] (II) AMDGPU(G0): Printing probed modes for output DisplayPort-1-1
[ 4.317] (II) AMDGPU(G0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 4.317] (II) AMDGPU(G0): Modeline "1920x1080"x120.0 285.50 1920 1968 2000 2080 1080 1083 1088 1144 +hsync +vsync (137.3 kHz e)
[ 4.317] (II) AMDGPU(G0): Modeline "1920x1080"x109.9 260.25 1920 1968 2000 2080 1080 1083 1088 1138 +hsync +vsync (125.1 kHz e)
[ 4.317] (II) AMDGPU(G0): Modeline "1920x1080"x99.9 235.50 1920 1968 2000 2080 1080 1083 1088 1133 +hsync +vsync (113.2 kHz e)
[ 4.317] (II) AMDGPU(G0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 4.317] (II) AMDGPU(G0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 4.317] (II) AMDGPU(G0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 4.317] (II) AMDGPU(G0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "1280x800"x60.0 148.50 1280 2008 2052 2200 800 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 4.318] (II) AMDGPU(G0): EDID for output DisplayPort-1-2
[ 4.318] (II) AMDGPU(G0): Manufacturer: ACI Model: 23f2 Serial#: 197110
[ 4.318] (II) AMDGPU(G0): Year: 2011 Week: 47
[ 4.318] (II) AMDGPU(G0): EDID Version: 1.3
[ 4.318] (II) AMDGPU(G0): Digital Display Input
[ 4.318] (II) AMDGPU(G0): Max Image Size [cm]: horiz.: 52 vert.: 29
[ 4.318] (II) AMDGPU(G0): Gamma: 2.20
[ 4.318] (II) AMDGPU(G0): DPMS capabilities: Off
[ 4.318] (II) AMDGPU(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 4.318] (II) AMDGPU(G0): First detailed timing is preferred mode
[ 4.318] (II) AMDGPU(G0): redX: 0.644 redY: 0.332 greenX: 0.286 greenY: 0.601
[ 4.318] (II) AMDGPU(G0): blueX: 0.152 blueY: 0.076 whiteX: 0.312 whiteY: 0.328
[ 4.318] (II) AMDGPU(G0): Supported established timings:
[ 4.318] (II) AMDGPU(G0): 720x400@70Hz
[ 4.318] (II) AMDGPU(G0): 640x480@60Hz
[ 4.318] (II) AMDGPU(G0): 640x480@67Hz
[ 4.318] (II) AMDGPU(G0): 640x480@72Hz
[ 4.318] (II) AMDGPU(G0): 640x480@75Hz
[ 4.318] (II) AMDGPU(G0): 800x600@56Hz
[ 4.318] (II) AMDGPU(G0): 800x600@60Hz
[ 4.318] (II) AMDGPU(G0): 800x600@72Hz
[ 4.318] (II) AMDGPU(G0): 800x600@75Hz
[ 4.318] (II) AMDGPU(G0): 832x624@75Hz
[ 4.318] (II) AMDGPU(G0): 1024x768@60Hz
[ 4.318] (II) AMDGPU(G0): 1024x768@70Hz
[ 4.318] (II) AMDGPU(G0): 1024x768@75Hz
[ 4.318] (II) AMDGPU(G0): 1280x1024@75Hz
[ 4.318] (II) AMDGPU(G0): Manufacturer's mask: 0
[ 4.318] (II) AMDGPU(G0): Supported standard timings:
[ 4.318] (II) AMDGPU(G0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 4.318] (II) AMDGPU(G0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 4.318] (II) AMDGPU(G0): #2: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 4.318] (II) AMDGPU(G0): #3: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 4.318] (II) AMDGPU(G0): #4: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 4.318] (II) AMDGPU(G0): Supported detailed timing:
[ 4.318] (II) AMDGPU(G0): clock: 148.5 MHz Image Size: 521 x 293 mm
[ 4.318] (II) AMDGPU(G0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 4.318] (II) AMDGPU(G0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 4.318] (II) AMDGPU(G0): Serial No: BBLMTF197110
[ 4.318] (II) AMDGPU(G0): Ranges: V min: 55 V max: 75 Hz, H min: 30 H max: 85 kHz, PixClock max 165 MHz
[ 4.318] (II) AMDGPU(G0): Monitor name: ASUS VH236H
[ 4.318] (II) AMDGPU(G0): EDID (in hex):
[ 4.318] (II) AMDGPU(G0): 00ffffffffffff000469f223f6010300
[ 4.318] (II) AMDGPU(G0): 2f15010380341d782ac720a455499927
[ 4.318] (II) AMDGPU(G0): 135054bfef00714f81809500b300d1c0
[ 4.318] (II) AMDGPU(G0): 010101010101023a801871382d40582c
[ 4.318] (II) AMDGPU(G0): 450009252100001e000000ff0042424c
[ 4.318] (II) AMDGPU(G0): 4d54463139373131300a000000fd0037
[ 4.318] (II) AMDGPU(G0): 4b1e5510000a202020202020000000fc
[ 4.318] (II) AMDGPU(G0): 0041535553205648323336480a2000ff
[ 4.318] (II) AMDGPU(G0): Printing probed modes for output DisplayPort-1-2
[ 4.318] (II) AMDGPU(G0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 4.318] (II) AMDGPU(G0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "1280x720"x60.0 148.50 1280 2008 2052 2200 720 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 4.318] (II) AMDGPU(G0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 4.318] (II) AMDGPU(G0): EDID for output HDMI-A-1-0
[ 4.318] (II) AMDGPU(G0): mem size init: gart size :1fe6ac000 vram size: s:1fca84000 visible:e492000
[ 4.318] (==) AMDGPU(G0): DPI set to (96, 96)
[ 4.319] (==) AMDGPU(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 4.319] (II) Loading sub module "ramdac"
[ 4.319] (II) LoadModule: "ramdac"
[ 4.319] (II) Module "ramdac" already built-in
[ 4.319] (II) UnloadModule: "fbdev"
[ 4.319] (II) Unloading fbdev
[ 4.319] (II) UnloadSubModule: "fbdevhw"
[ 4.319] (II) Unloading fbdevhw
[ 4.319] (II) UnloadModule: "vesa"
[ 4.319] (II) Unloading vesa
[ 4.320] (==) modeset(0): Backing store enabled
[ 4.320] (==) modeset(0): Silken mouse enabled
[ 4.321] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 4.321] (==) modeset(0): DPMS enabled
[ 4.321] (II) AMDGPU(G0): [DRI2] Setup complete
[ 4.321] (II) AMDGPU(G0): [DRI2] DRI driver: radeonsi
[ 4.321] (II) AMDGPU(G0): [DRI2] VDPAU driver: radeonsi
[ 4.322] (II) AMDGPU(G0): Front buffer pitch: 4096 bytes
[ 4.322] (==) AMDGPU(G0): Backing store enabled
[ 4.322] (II) AMDGPU(G0): Direct rendering enabled
[ 4.364] (II) AMDGPU(G0): Use GLAMOR acceleration.
[ 4.364] (II) AMDGPU(G0): Acceleration enabled
[ 4.364] (==) AMDGPU(G0): DPMS enabled
[ 4.364] (==) AMDGPU(G0): Silken mouse enabled
[ 4.400] (II) Initializing extension Generic Event Extension
[ 4.401] (II) Initializing extension SHAPE
[ 4.401] (II) Initializing extension MIT-SHM
[ 4.401] (II) Initializing extension XInputExtension
[ 4.401] (II) Initializing extension XTEST
[ 4.402] (II) Initializing extension BIG-REQUESTS
[ 4.402] (II) Initializing extension SYNC
[ 4.402] (II) Initializing extension XKEYBOARD
[ 4.402] (II) Initializing extension XC-MISC
[ 4.402] (II) Initializing extension SECURITY
[ 4.402] (II) Initializing extension XFIXES
[ 4.402] (II) Initializing extension RENDER
[ 4.402] (II) Initializing extension RANDR
[ 4.402] (II) Initializing extension COMPOSITE
[ 4.403] (II) Initializing extension DAMAGE
[ 4.403] (II) Initializing extension MIT-SCREEN-SAVER
[ 4.403] (II) Initializing extension DOUBLE-BUFFER
[ 4.403] (II) Initializing extension RECORD
[ 4.403] (II) Initializing extension DPMS
[ 4.403] (II) Initializing extension Present
[ 4.403] (II) Initializing extension DRI3
[ 4.403] (II) Initializing extension X-Resource
[ 4.403] (II) Initializing extension XVideo
[ 4.403] (II) Initializing extension XVideo-MotionCompensation
[ 4.403] (II) Initializing extension SELinux
[ 4.403] (II) SELinux: Disabled on system
[ 4.403] (II) Initializing extension GLX
[ 4.404] (II) AIGLX: Screen 0 is not DRI2 capable
[ 4.435] (II) IGLX: Loaded and initialized swrast
[ 4.435] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 4.435] (II) Initializing extension XFree86-VidModeExtension
[ 4.435] (II) Initializing extension XFree86-DGA
[ 4.435] (II) Initializing extension XFree86-DRI
[ 4.435] (II) Initializing extension DRI2
[ 4.518] (II) modeset(0): Damage tracking initialized
[ 4.518] (II) modeset(0): Setting screen physical size to 270 x 203
[ 4.572] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 4.572] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 4.572] (II) LoadModule: "libinput"
[ 4.572] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 4.579] (II) Module libinput: vendor="X.Org Foundation"
[ 4.579] compiled for 1.20.4, module version = 0.29.0
[ 4.579] Module class: X.Org XInput Driver
[ 4.579] ABI class: X.Org XInput driver, version 24.1
[ 4.579] (II) Using input driver 'libinput' for 'Power Button'
[ 4.580] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 27 paused 0
[ 4.580] (**) Power Button: always reports core events
[ 4.580] (**) Option "Device" "/dev/input/event0"
[ 4.580] (**) Option "_source" "server/udev"
[ 4.588] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 4.588] (II) event0 - Power Button: device is a keyboard
[ 4.588] (II) event0 - Power Button: device removed
[ 4.588] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input0/event0"
[ 4.588] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 4.588] (**) Option "xkb_model" "pc105"
[ 4.588] (**) Option "xkb_layout" "us"
[ 4.589] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 4.589] (II) event0 - Power Button: device is a keyboard
[ 4.590] (II) config/udev: Adding input device QEMU QEMU USB Tablet (/dev/input/event2)
[ 4.590] (**) QEMU QEMU USB Tablet: Applying InputClass "libinput pointer catchall"
[ 4.590] (II) Using input driver 'libinput' for 'QEMU QEMU USB Tablet'
[ 4.654] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 30 paused 0
[ 4.654] (**) QEMU QEMU USB Tablet: always reports core events
[ 4.654] (**) Option "Device" "/dev/input/event2"
[ 4.654] (**) Option "_source" "server/udev"
[ 4.655] (II) event2 - QEMU QEMU USB Tablet: is tagged by udev as: Mouse
[ 4.655] (II) event2 - QEMU QEMU USB Tablet: device is a pointer
[ 4.655] (II) event2 - QEMU QEMU USB Tablet: device removed
[ 4.656] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1:1.0/0003:0627:0001.0001/input/input4/event2"
[ 4.656] (II) XINPUT: Adding extended input device "QEMU QEMU USB Tablet" (type: MOUSE, id 7)
[ 4.656] (**) Option "AccelerationScheme" "none"
[ 4.656] (**) QEMU QEMU USB Tablet: (accel) selected scheme none/0
[ 4.656] (**) QEMU QEMU USB Tablet: (accel) acceleration factor: 2.000
[ 4.656] (**) QEMU QEMU USB Tablet: (accel) acceleration threshold: 4
[ 4.657] (II) event2 - QEMU QEMU USB Tablet: is tagged by udev as: Mouse
[ 4.657] (II) event2 - QEMU QEMU USB Tablet: device is a pointer
[ 4.658] (II) config/udev: Adding input device QEMU QEMU USB Tablet (/dev/input/mouse0)
[ 4.658] (II) No input driver specified, ignoring this device.
[ 4.658] (II) This device may have been added with another device file.
[ 4.658] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse (/dev/input/event3)
[ 4.658] (**) Logitech G502 HERO Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 4.658] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse'
[ 4.722] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 31 paused 0
[ 4.722] (**) Logitech G502 HERO Gaming Mouse: always reports core events
[ 4.722] (**) Option "Device" "/dev/input/event3"
[ 4.722] (**) Option "_source" "server/udev"
[ 4.723] (II) event3 - Logitech G502 HERO Gaming Mouse: is tagged by udev as: Mouse
[ 4.723] (II) event3 - Logitech G502 HERO Gaming Mouse: device is a pointer
[ 4.723] (II) event3 - Logitech G502 HERO Gaming Mouse: device removed
[ 4.723] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.1/3-1.1:1.0/0003:046D:C08B.0002/input/input5/event3"
[ 4.723] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse" (type: MOUSE, id 8)
[ 4.723] (**) Option "AccelerationScheme" "none"
[ 4.723] (**) Logitech G502 HERO Gaming Mouse: (accel) selected scheme none/0
[ 4.723] (**) Logitech G502 HERO Gaming Mouse: (accel) acceleration factor: 2.000
[ 4.723] (**) Logitech G502 HERO Gaming Mouse: (accel) acceleration threshold: 4
[ 4.725] (II) event3 - Logitech G502 HERO Gaming Mouse: is tagged by udev as: Mouse
[ 4.725] (II) event3 - Logitech G502 HERO Gaming Mouse: device is a pointer
[ 4.726] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse (/dev/input/mouse1)
[ 4.726] (II) No input driver specified, ignoring this device.
[ 4.726] (II) This device may have been added with another device file.
[ 4.726] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse Keyboard (/dev/input/event4)
[ 4.726] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 4.727] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse Keyboard'
[ 4.728] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 32 paused 0
[ 4.728] (**) Logitech G502 HERO Gaming Mouse Keyboard: always reports core events
[ 4.728] (**) Option "Device" "/dev/input/event4"
[ 4.728] (**) Option "_source" "server/udev"
[ 4.729] (II) event4 - Logitech G502 HERO Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 4.729] (II) event4 - Logitech G502 HERO Gaming Mouse Keyboard: device is a keyboard
[ 4.729] (II) event4 - Logitech G502 HERO Gaming Mouse Keyboard: device removed
[ 4.729] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:046D:C08B.0003/input/input6/event4"
[ 4.729] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse Keyboard" (type: KEYBOARD, id 9)
[ 4.729] (**) Option "xkb_model" "pc105"
[ 4.729] (**) Option "xkb_layout" "us"
[ 4.731] (II) event4 - Logitech G502 HERO Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 4.731] (II) event4 - Logitech G502 HERO Gaming Mouse Keyboard: device is a keyboard
[ 4.732] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse Consumer Control (/dev/input/event5)
[ 4.732] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 4.732] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse Consumer Control'
[ 4.732] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 33 paused 0
[ 4.732] (**) Logitech G502 HERO Gaming Mouse Consumer Control: always reports core events
[ 4.732] (**) Option "Device" "/dev/input/event5"
[ 4.732] (**) Option "_source" "server/udev"
[ 4.734] (II) event5 - Logitech G502 HERO Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[ 4.734] (II) event5 - Logitech G502 HERO Gaming Mouse Consumer Control: device is a keyboard
[ 4.734] (II) event5 - Logitech G502 HERO Gaming Mouse Consumer Control: device removed
[ 4.734] (II) libinput: Logitech G502 HERO Gaming Mouse Consumer Control: needs a virtual subdevice
[ 4.734] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:046D:C08B.0003/input/input7/event5"
[ 4.734] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse Consumer Control" (type: MOUSE, id 10)
[ 4.734] (**) Option "AccelerationScheme" "none"
[ 4.734] (**) Logitech G502 HERO Gaming Mouse Consumer Control: (accel) selected scheme none/0
[ 4.734] (**) Logitech G502 HERO Gaming Mouse Consumer Control: (accel) acceleration factor: 2.000
[ 4.734] (**) Logitech G502 HERO Gaming Mouse Consumer Control: (accel) acceleration threshold: 4
[ 4.735] (II) event5 - Logitech G502 HERO Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[ 4.735] (II) event5 - Logitech G502 HERO Gaming Mouse Consumer Control: device is a keyboard
[ 4.736] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse System Control (/dev/input/event7)
[ 4.736] (**) Logitech G502 HERO Gaming Mouse System Control: Applying InputClass "libinput keyboard catchall"
[ 4.736] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse System Control'
[ 4.737] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 34 paused 0
[ 4.737] (**) Logitech G502 HERO Gaming Mouse System Control: always reports core events
[ 4.737] (**) Option "Device" "/dev/input/event7"
[ 4.737] (**) Option "_source" "server/udev"
[ 4.739] (II) event7 - Logitech G502 HERO Gaming Mouse System Control: is tagged by udev as: Keyboard
[ 4.739] (II) event7 - Logitech G502 HERO Gaming Mouse System Control: device is a keyboard
[ 4.739] (II) event7 - Logitech G502 HERO Gaming Mouse System Control: device removed
[ 4.739] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:046D:C08B.0003/input/input8/event7"
[ 4.739] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse System Control" (type: KEYBOARD, id 11)
[ 4.739] (**) Option "xkb_model" "pc105"
[ 4.739] (**) Option "xkb_layout" "us"
[ 4.740] (II) event7 - Logitech G502 HERO Gaming Mouse System Control: is tagged by udev as: Keyboard
[ 4.740] (II) event7 - Logitech G502 HERO Gaming Mouse System Control: device is a keyboard
[ 4.741] (II) config/udev: Adding input device Logitech G432 Gaming Headset Consumer Control (/dev/input/event10)
[ 4.741] (**) Logitech G432 Gaming Headset Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 4.741] (II) Using input driver 'libinput' for 'Logitech G432 Gaming Headset Consumer Control'
[ 4.742] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 35 paused 0
[ 4.742] (**) Logitech G432 Gaming Headset Consumer Control: always reports core events
[ 4.742] (**) Option "Device" "/dev/input/event10"
[ 4.742] (**) Option "_source" "server/udev"
[ 4.743] (II) event10 - Logitech G432 Gaming Headset Consumer Control: is tagged by udev as: Keyboard
[ 4.744] (II) event10 - Logitech G432 Gaming Headset Consumer Control: device is a keyboard
[ 4.744] (II) event10 - Logitech G432 Gaming Headset Consumer Control: device removed
[ 4.744] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.2/3-1.2:1.3/0003:046D:0A9C.0006/input/input13/event10"
[ 4.744] (II) XINPUT: Adding extended input device "Logitech G432 Gaming Headset Consumer Control" (type: KEYBOARD, id 12)
[ 4.744] (**) Option "xkb_model" "pc105"
[ 4.744] (**) Option "xkb_layout" "us"
[ 4.745] (II) event10 - Logitech G432 Gaming Headset Consumer Control: is tagged by udev as: Keyboard
[ 4.745] (II) event10 - Logitech G432 Gaming Headset Consumer Control: device is a keyboard
[ 4.746] (II) config/udev: Adding input device Logitech G432 Gaming Headset (/dev/input/event11)
[ 4.746] (**) Logitech G432 Gaming Headset: Applying InputClass "libinput keyboard catchall"
[ 4.746] (II) Using input driver 'libinput' for 'Logitech G432 Gaming Headset'
[ 4.747] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 36 paused 0
[ 4.747] (**) Logitech G432 Gaming Headset: always reports core events
[ 4.747] (**) Option "Device" "/dev/input/event11"
[ 4.747] (**) Option "_source" "server/udev"
[ 4.748] (II) event11 - Logitech G432 Gaming Headset: is tagged by udev as: Keyboard
[ 4.748] (II) event11 - Logitech G432 Gaming Headset: device is a keyboard
[ 4.749] (II) event11 - Logitech G432 Gaming Headset: device removed
[ 4.749] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.2/3-1.2:1.3/0003:046D:0A9C.0006/input/input14/event11"
[ 4.749] (II) XINPUT: Adding extended input device "Logitech G432 Gaming Headset" (type: KEYBOARD, id 13)
[ 4.749] (**) Option "xkb_model" "pc105"
[ 4.749] (**) Option "xkb_layout" "us"
[ 4.750] (II) event11 - Logitech G432 Gaming Headset: is tagged by udev as: Keyboard
[ 4.750] (II) event11 - Logitech G432 Gaming Headset: device is a keyboard
[ 4.751] (II) config/udev: Adding input device Logitech Logitech G710 Keyboard (/dev/input/event12)
[ 4.751] (**) Logitech Logitech G710 Keyboard: Applying InputClass "libinput keyboard catchall"
[ 4.751] (II) Using input driver 'libinput' for 'Logitech Logitech G710 Keyboard'
[ 4.752] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 37 paused 0
[ 4.752] (**) Logitech Logitech G710 Keyboard: always reports core events
[ 4.752] (**) Option "Device" "/dev/input/event12"
[ 4.752] (**) Option "_source" "server/udev"
[ 4.753] (II) event12 - Logitech Logitech G710 Keyboard: is tagged by udev as: Keyboard
[ 4.753] (II) event12 - Logitech Logitech G710 Keyboard: device is a keyboard
[ 4.753] (II) event12 - Logitech Logitech G710 Keyboard: device removed
[ 4.753] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.3/3-1.3:1.0/0003:046D:C24D.0007/input/input17/event12"
[ 4.753] (II) XINPUT: Adding extended input device "Logitech Logitech G710 Keyboard" (type: KEYBOARD, id 14)
[ 4.753] (**) Option "xkb_model" "pc105"
[ 4.753] (**) Option "xkb_layout" "us"
[ 4.755] (II) event12 - Logitech Logitech G710 Keyboard: is tagged by udev as: Keyboard
[ 4.755] (II) event12 - Logitech Logitech G710 Keyboard: device is a keyboard
[ 4.756] (II) config/udev: Adding input device Logitech Logitech G710 Keyboard (/dev/input/event13)
[ 4.756] (**) Logitech Logitech G710 Keyboard: Applying InputClass "libinput keyboard catchall"
[ 4.756] (II) Using input driver 'libinput' for 'Logitech Logitech G710 Keyboard'
[ 4.757] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 38 paused 0
[ 4.757] (**) Logitech Logitech G710 Keyboard: always reports core events
[ 4.757] (**) Option "Device" "/dev/input/event13"
[ 4.757] (**) Option "_source" "server/udev"
[ 4.758] (II) event13 - Logitech Logitech G710 Keyboard: is tagged by udev as: Keyboard
[ 4.758] (II) event13 - Logitech Logitech G710 Keyboard: device is a keyboard
[ 4.758] (II) event13 - Logitech Logitech G710 Keyboard: device removed
[ 4.758] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.3/3-1.3:1.1/0003:046D:C24D.0008/input/input18/event13"
[ 4.758] (II) XINPUT: Adding extended input device "Logitech Logitech G710 Keyboard" (type: KEYBOARD, id 15)
[ 4.758] (**) Option "xkb_model" "pc105"
[ 4.758] (**) Option "xkb_layout" "us"
[ 4.760] (II) event13 - Logitech Logitech G710 Keyboard: is tagged by udev as: Keyboard
[ 4.760] (II) event13 - Logitech Logitech G710 Keyboard: device is a keyboard
[ 4.761] (II) config/udev: Adding input device Logitech Logitech G710 Keyboard Consumer Control (/dev/input/event14)
[ 4.761] (**) Logitech Logitech G710 Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 4.761] (II) Using input driver 'libinput' for 'Logitech Logitech G710 Keyboard Consumer Control'
[ 4.761] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 39 paused 0
[ 4.761] (**) Logitech Logitech G710 Keyboard Consumer Control: always reports core events
[ 4.761] (**) Option "Device" "/dev/input/event14"
[ 4.761] (**) Option "_source" "server/udev"
[ 4.763] (II) event14 - Logitech Logitech G710 Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 4.763] (II) event14 - Logitech Logitech G710 Keyboard Consumer Control: device is a keyboard
[ 4.763] (II) event14 - Logitech Logitech G710 Keyboard Consumer Control: device removed
[ 4.763] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.3/3-1.3:1.1/0003:046D:C24D.0008/input/input19/event14"
[ 4.763] (II) XINPUT: Adding extended input device "Logitech Logitech G710 Keyboard Consumer Control" (type: KEYBOARD, id 16)
[ 4.763] (**) Option "xkb_model" "pc105"
[ 4.763] (**) Option "xkb_layout" "us"
[ 4.764] (II) event14 - Logitech Logitech G710 Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 4.764] (II) event14 - Logitech Logitech G710 Keyboard Consumer Control: device is a keyboard
[ 4.765] (II) config/udev: Adding input device Winbond Electronics Corp Hermon USB hidmouse Device (/dev/input/event6)
[ 4.765] (**) Winbond Electronics Corp Hermon USB hidmouse Device: Applying InputClass "libinput pointer catchall"
[ 4.765] (II) Using input driver 'libinput' for 'Winbond Electronics Corp Hermon USB hidmouse Device'
[ 4.826] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 40 paused 0
[ 4.826] (**) Winbond Electronics Corp Hermon USB hidmouse Device: always reports core events
[ 4.826] (**) Option "Device" "/dev/input/event6"
[ 4.826] (**) Option "_source" "server/udev"
[ 4.827] (II) event6 - Winbond Electronics Corp Hermon USB hidmouse Device: is tagged by udev as: Mouse
[ 4.827] (II) event6 - Winbond Electronics Corp Hermon USB hidmouse Device: device is a pointer
[ 4.828] (II) event6 - Winbond Electronics Corp Hermon USB hidmouse Device: device removed
[ 4.828] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:1b.0/usb4/4-1/4-1.6/4-1.6:1.0/0003:0557:2221.0004/input/input11/event6"
[ 4.828] (II) XINPUT: Adding extended input device "Winbond Electronics Corp Hermon USB hidmouse Device" (type: MOUSE, id 17)
[ 4.828] (**) Option "AccelerationScheme" "none"
[ 4.828] (**) Winbond Electronics Corp Hermon USB hidmouse Device: (accel) selected scheme none/0
[ 4.828] (**) Winbond Electronics Corp Hermon USB hidmouse Device: (accel) acceleration factor: 2.000
[ 4.828] (**) Winbond Electronics Corp Hermon USB hidmouse Device: (accel) acceleration threshold: 4
[ 4.829] (II) event6 - Winbond Electronics Corp Hermon USB hidmouse Device: is tagged by udev as: Mouse
[ 4.829] (II) event6 - Winbond Electronics Corp Hermon USB hidmouse Device: device is a pointer
[ 4.830] (II) config/udev: Adding input device Winbond Electronics Corp Hermon USB hidmouse Device (/dev/input/mouse2)
[ 4.830] (II) No input driver specified, ignoring this device.
[ 4.830] (II) This device may have been added with another device file.
[ 4.831] (II) config/udev: Adding input device Winbond Electronics Corp Hermon USB hidmouse Device (/dev/input/event8)
[ 4.831] (**) Winbond Electronics Corp Hermon USB hidmouse Device: Applying InputClass "libinput keyboard catchall"
[ 4.831] (II) Using input driver 'libinput' for 'Winbond Electronics Corp Hermon USB hidmouse Device'
[ 4.832] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 41 paused 0
[ 4.832] (**) Winbond Electronics Corp Hermon USB hidmouse Device: always reports core events
[ 4.832] (**) Option "Device" "/dev/input/event8"
[ 4.832] (**) Option "_source" "server/udev"
[ 4.834] (II) event8 - Winbond Electronics Corp Hermon USB hidmouse Device: is tagged by udev as: Keyboard
[ 4.834] (II) event8 - Winbond Electronics Corp Hermon USB hidmouse Device: device is a keyboard
[ 4.834] (II) event8 - Winbond Electronics Corp Hermon USB hidmouse Device: device removed
[ 4.834] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:1b.0/usb4/4-1/4-1.6/4-1.6:1.1/0003:0557:2221.0005/input/input12/event8"
[ 4.834] (II) XINPUT: Adding extended input device "Winbond Electronics Corp Hermon USB hidmouse Device" (type: KEYBOARD, id 18)
[ 4.834] (**) Option "xkb_model" "pc105"
[ 4.834] (**) Option "xkb_layout" "us"
[ 4.836] (II) event8 - Winbond Electronics Corp Hermon USB hidmouse Device: is tagged by udev as: Keyboard
[ 4.836] (II) event8 - Winbond Electronics Corp Hermon USB hidmouse Device: device is a keyboard
[ 4.836] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event1)
[ 4.836] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 4.836] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 4.837] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 42 paused 0
[ 4.837] (**) AT Translated Set 2 keyboard: always reports core events
[ 4.837] (**) Option "Device" "/dev/input/event1"
[ 4.837] (**) Option "_source" "server/udev"
[ 4.838] (II) event1 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 4.838] (II) event1 - AT Translated Set 2 keyboard: device is a keyboard
[ 4.839] (II) event1 - AT Translated Set 2 keyboard: device removed
[ 4.839] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input1/event1"
[ 4.839] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 19)
[ 4.839] (**) Option "xkb_model" "pc105"
[ 4.839] (**) Option "xkb_layout" "us"
[ 4.840] (II) event1 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 4.840] (II) event1 - AT Translated Set 2 keyboard: device is a keyboard
[ 4.841] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/event9)
[ 4.841] (**) ImExPS/2 Generic Explorer Mouse: Applying InputClass "libinput pointer catchall"
[ 4.841] (II) Using input driver 'libinput' for 'ImExPS/2 Generic Explorer Mouse'
[ 4.842] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 43 paused 0
[ 4.842] (**) ImExPS/2 Generic Explorer Mouse: always reports core events
[ 4.842] (**) Option "Device" "/dev/input/event9"
[ 4.842] (**) Option "_source" "server/udev"
[ 4.843] (II) event9 - ImExPS/2 Generic Explorer Mouse: is tagged by udev as: Mouse
[ 4.843] (II) event9 - ImExPS/2 Generic Explorer Mouse: device is a pointer
[ 4.843] (II) event9 - ImExPS/2 Generic Explorer Mouse: device removed
[ 4.843] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input3/event9"
[ 4.843] (II) XINPUT: Adding extended input device "ImExPS/2 Generic Explorer Mouse" (type: MOUSE, id 20)
[ 4.843] (**) Option "AccelerationScheme" "none"
[ 4.843] (**) ImExPS/2 Generic Explorer Mouse: (accel) selected scheme none/0
[ 4.843] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration factor: 2.000
[ 4.843] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration threshold: 4
[ 4.844] (II) event9 - ImExPS/2 Generic Explorer Mouse: is tagged by udev as: Mouse
[ 4.844] (II) event9 - ImExPS/2 Generic Explorer Mouse: device is a pointer
[ 4.845] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/mouse3)
[ 4.845] (II) No input driver specified, ignoring this device.
[ 4.845] (II) This device may have been added with another device file.
[ 4.851] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 4.851] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse Consumer Control'
[ 4.851] (II) systemd-logind: returning pre-existing fd for /dev/input/event5 13:69
[ 4.851] (**) Logitech G502 HERO Gaming Mouse Consumer Control: always reports core events
[ 4.851] (**) Option "Device" "/dev/input/event5"
[ 4.851] (**) Option "_source" "_driver/libinput"
[ 4.851] (II) libinput: Logitech G502 HERO Gaming Mouse Consumer Control: is a virtual subdevice
[ 4.851] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/0000:06:11.0/usb3/3-1/3-1.1/3-1.1:1.1/0003:046D:C08B.0003/input/input7/event5"
[ 4.851] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse Consumer Control" (type: KEYBOARD, id 21)
[ 4.851] (**) Option "xkb_model" "pc105"
[ 4.851] (**) Option "xkb_layout" "us"
[ 5.564] (II) modeset(0): EDID vendor "RHT", prod id 4660
[ 5.564] (II) modeset(0): Using EDID range info for horizontal sync
[ 5.564] (II) modeset(0): Using EDID range info for vertical refresh
[ 5.564] (II) modeset(0): Printing DDC gathered Modelines:
[ 5.564] (II) modeset(0): Modeline "1024x768"x0.0 82.29 1024 1280 1310 1382 768 771 774 794 -hsync -vsync (59.5 kHz eP)
[ 5.564] (II) modeset(0): Modeline "1280x768"x0.0 79.50 1280 1344 1472 1664 768 771 778 798 -hsync +vsync (47.8 kHz e)
[ 5.564] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 5.564] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 5.564] (II) modeset(0): Modeline "1360x768"x0.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[ 5.564] (II) modeset(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 5.564] (II) modeset(0): Modeline "1400x1050"x0.0 121.75 1400 1488 1632 1864 1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[ 5.564] (II) modeset(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 5.564] (II) modeset(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 5.564] (II) modeset(0): Modeline "1792x1344"x0.0 204.75 1792 1920 2120 2448 1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[ 5.564] (II) modeset(0): Modeline "1856x1392"x0.0 218.25 1856 1952 2176 2528 1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[ 5.564] (II) modeset(0): Modeline "1920x1200"x0.0 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[ 5.564] (II) modeset(0): Modeline "1920x1440"x0.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[ 5.564] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 5.564] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 5.564] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 5.564] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 5.564] (II) modeset(0): Modeline "2048x1152"x60.0 197.97 2048 2184 2408 2768 1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[ 5.564] (II) modeset(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[ 5.755] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 62.147] (**) Option "fd" "27"
[ 62.147] (II) event0 - Power Button: device removed
[ 62.147] (**) Option "fd" "30"
[ 62.147] (II) event2 - QEMU QEMU USB Tablet: device removed
[ 62.147] (**) Option "fd" "31"
[ 62.147] (II) event3 - Logitech G502 HERO Gaming Mouse: device removed
[ 62.147] (**) Option "fd" "32"
[ 62.147] (II) event4 - Logitech G502 HERO Gaming Mouse Keyboard: device removed
[ 62.147] (**) Option "fd" "33"
[ 62.147] (**) Option "fd" "34"
[ 62.147] (II) event7 - Logitech G502 HERO Gaming Mouse System Control: device removed
[ 62.147] (**) Option "fd" "35"
[ 62.147] (II) event10 - Logitech G432 Gaming Headset Consumer Control: device removed
[ 62.147] (**) Option "fd" "36"
[ 62.147] (II) event11 - Logitech G432 Gaming Headset: device removed
[ 62.147] (**) Option "fd" "37"
[ 62.147] (II) event12 - Logitech Logitech G710 Keyboard: device removed
[ 62.147] (**) Option "fd" "38"
[ 62.147] (II) event13 - Logitech Logitech G710 Keyboard: device removed
[ 62.147] (**) Option "fd" "39"
[ 62.148] (II) event14 - Logitech Logitech G710 Keyboard Consumer Control: device removed
[ 62.148] (**) Option "fd" "40"
[ 62.148] (II) event6 - Winbond Electronics Corp Hermon USB hidmouse Device: device removed
[ 62.148] (**) Option "fd" "41"
[ 62.148] (II) event8 - Winbond Electronics Corp Hermon USB hidmouse Device: device removed
[ 62.148] (**) Option "fd" "42"
[ 62.148] (II) event1 - AT Translated Set 2 keyboard: device removed
[ 62.148] (**) Option "fd" "43"
[ 62.148] (II) event9 - ImExPS/2 Generic Explorer Mouse: device removed
[ 62.148] (**) Option "fd" "33"
[ 62.148] (II) event5 - Logitech G502 HERO Gaming Mouse Consumer Control: device removed
[ 62.149] (II) UnloadModule: "libinput"
[ 62.149] (II) systemd-logind: not releasing fd for 13:69, still in use
[ 62.150] (II) UnloadModule: "libinput"
[ 62.150] (II) systemd-logind: releasing fd for 13:73
[ 62.152] (II) UnloadModule: "libinput"
[ 62.152] (II) systemd-logind: releasing fd for 13:65
[ 62.154] (II) UnloadModule: "libinput"
[ 62.154] (II) systemd-logind: releasing fd for 13:72
[ 62.158] (II) UnloadModule: "libinput"
[ 62.158] (II) systemd-logind: releasing fd for 13:70
[ 62.159] (II) UnloadModule: "libinput"
[ 62.159] (II) systemd-logind: releasing fd for 13:78
[ 62.159] (II) systemd-logind: releasing fd for 13:77
[ 62.160] (II) UnloadModule: "libinput"
[ 62.160] (II) systemd-logind: releasing fd for 13:76
[ 62.161] (II) UnloadModule: "libinput"
[ 62.161] (II) systemd-logind: releasing fd for 13:75
[ 62.161] (II) systemd-logind: releasing fd for 13:74
[ 62.162] (II) UnloadModule: "libinput"
[ 62.162] (II) systemd-logind: releasing fd for 13:71
[ 62.162] (II) systemd-logind: releasing fd for 13:69
[ 62.163] (II) UnloadModule: "libinput"
[ 62.163] (II) systemd-logind: releasing fd for 13:68
[ 62.164] (II) UnloadModule: "libinput"
[ 62.164] (II) systemd-logind: releasing fd for 13:67
[ 62.164] (II) systemd-logind: releasing fd for 13:66
[ 62.166] (II) UnloadModule: "libinput"
[ 62.166] (II) systemd-logind: releasing fd for 13:64
[ 62.172] (II) Server terminated successfully (0). Closing log file.
