For some context, inthe past I have been running both TrueNAS and OPNsense as virtual machines. I have recently migrated my OPNsense to a dedicated server, and I would like to do the same to my TrueNAS instance.
In terms of the hardware that I have and what is it currently used for, we have:
- Main Server: i7-9700X, 6x 16Gb RAM, 250gb NVMe boot, 1Tb NVMe Mirror for VMs (Proxmox), 5x 4Tn HDD for TrueNAS
- Firewall: Pentium G6400, 2x 8Gb RAM
- Backup Server: i5-6500, 2x 8RAM, 5x 1Tb HDD (TrueNAS)
What I was considering is I could either:
A: Use the Backup Server as the main Storage server and then figure out another backup solution, but I am afraid the CPU might not be strong enough to handle a 10g transfer. For backups, it’s okay as it gets automatically powered on and I don’t particularly care how long it takes for the backup to happen as it is not performance critical, but for a main storage source, it may be a bottleneck.
B: Purchase some more hardware to set up a dedicated storage server:
I already own some RAM, a rackmount case and a PSU, so I only really need a motherboard, a CPU and a cooler to get going.
PRO:
- no extra hardware to buy for now
CON:
- no backup server
- CPU might be underpowered for 10g
B1: I found an X99 kit for 215$ which contains:
- Asus Strix X99 motherboard
- i7-6850K
- 4x 8Gb DDR4
- 400Gb Intel 750 PCIe
- some cooler master case
PRO:
- plenty PCIe lanes
- bifurcation support
- room for memory expansion
- plenty CPU horsepower to also run some additional services
CON:
- more expensive than the other solutions
- no ECC
- no IPMI
B2: I could get a kit with a Supermicro board for 100$, so half the price, that contains:
- Supermicro X10SLM-F motherboard
- i3-4170 CPU
- 4x 4Gb ECC DDR3
PRO:
- cheap
- ECC support
- IPMI support
CON:
- limited pcie expansion
- limited memory expansion
- underpowered CPU
What do you think? Are there other options I did not consider? Which one would you pick and why? I am personally leaning towards the 6850k. Seems like a decent price to me.
