Hardware Compatibility
Hi Guys, Im a console gamer making a good change and moving to PC because its just better than a console and the next-gen consoles don't really look that good. Anyways I'm not sure if the parts I'm choosing for my build are all compatible and If they are woth the money. Please feel free to suggest new parts for my build if any of my parts are not compatible with the others. Keep in mind that I want to be able to run Crysis 2 at 50-60 frames per second on the max settings(1080p).
NZXT Phantom 820 Matte Black (Case)
Asus Sabertooth z77 Motherboard (MOBO)
EVGA GTX660Ti 3GB Super Clock (GPU)
Cooler Master 850W Silent Pro (PSU)
Intel Core i5 3570K (CPU)
Corsair Vengeance 16GB 1600MHz (RAM)
Western Digital 1TB SATA3 64M HDD (STORAGE)
Cooler Master Hyper 212 Evo CPU Fan (CPU COOLING)
OCZ Vertex 4 128GB SSD (BOOT DRIVE)
I will also be using sony vegas to render and edit as well :)
what is your budget
roughly around $2000 (I live in Australia) :)
that case costs to much try the new coolermaster storm scout 2 or the coolermaster trooper try to get a 670 and maybe look at an amd fx 8350 and oc itand if you live in austalia mate it is really hot there yesterday
Thanks for the reply man, but I think I'll Stick to my 3570K but I'll have a look at the case and I have been trying my hardest to run two GTX 660Ti's in SLI.
Yea Different Case and Go for 8GB of ram instea of 16GB, oh and get a smaller psu unless you plan to OC/SLI  and Watercool everything with like 5 HDD's and a Bunch of fans, you can also bring the cost down by not buying a higher end ASUS board as a good bit of the price will be for the premium Mobo because its ASUS, Take a look at the Asrock and Gigabyte Boards
OK Man Thanks 4 the reply! can you tell me if my parts are compatible
