Hardware and Software suggestions for Ubuntu based media centre PC
I wish to build a media PC for my father. It would be used to play a variety of embarrassing 80s music alongside 2K DVDs. I already have an old FM1 socket motherboard alongside an APU. I believe that I will be able to find a cheap PSU and case by myself. However, I want to ask the Internet communities what would be a good option in terms of a sound card for 5.1 surround sound.
Also I want to make this media center controllable by a standard universal TV remote. I understand that there are all-in-one media centre options available to Linux, what I would like to know in this regard is are there any sensors that can detect TV remote input? and are there any media centers that are optimized towards the simple input of this type of device?
XBMC (X Box Media Center) which has been renamed to Kodi may be a good option for you. You will need an IR receiver or whatever on your PC though.
http://kodi.wiki/view/XBMCbuntu
You can control the machine with your cell phone (android) as long as both devices are connected to the same network.
Yes, Kodi and an intel NUC is a good option for media centre systems. Several of the NUCs come with IR receivers built-in. I would check the device compatibility list though beforehand to make sure you find the appropriate remote control to use with them. You would also need to pick up a USB external disk player to play the DVDs but these are relatively cheap nowadays. Using a smartphone to control it would save the cost of the remote though like @LinuxMaster9 posted.
Thanks guys, these are all really great suggestions, I already have a PC available, so I may bypass the NUC, but other than that Kodi looks like a great fit. And it just so happens that my father got a new Android phone from work last week, so I am all set there.
the remote will work on Any android device. Tablet or phone.
If you want to control XBMC with a standard T.V remote, you might want to look at this https://flirc.tv/product/flirc/
There aren't a ton of decent options when it comes to sound cards for a reasonable price, so if your motherboard isn't already 5.1 surround sound compatible, I would get this: http://www.newegg.com/Product/Product.aspx?Item=9SIA0ZX2C39501&cm_re=surround_sound_card-_-29-128-013-_-Product - guaranteed to support Linux kernels 2.6 and up according to StarTech.
