I am glad you bought the Huion brand to my attention, I hadn’t heard of them yet.
I do admit the Wacom tips wear quickly.
But artists are willing to put up with that because the design of their less durable plastic tips on top of their specially textured tablets are perfectly matched to FEEL just like pencil on paper.
I have always tried to have a tablet or other oddware controllers on my PC’s. AutoCAD used a tablet for pointing and commands. I didn’t like a trackball for graphic’s but that’s individual preference. I would like to try a 3D space navigator because I use engineering CAD to make 3D models.
You seem to like comment on everything, but you missed this one earlier? /s
I ask you to comment on.
I’m not sure if having the scratch disk on D:\ is as important in the age of SSD’s? s e a r c h i n g . . .
From Adobe: Recommendations for setting scratch disk preferences
For best performance, connect the scratch disks to a compatible port that has the highest bandwidth limit of all the available ports. The bandwidth limits for various ports are as follows:
Thunderbolt = 10GB/sec
eSATA = 600MB/sec
PCIe = 500MB/sec
USB3 = 400MB/sec
USB2 = 35MB/sec
To improve performance, set the scratch disk to a defragmented hard disk that has plenty of unused space and fast read/write speeds. If you have more than one hard drive, you can specify additional scratch disks. Photoshop supports up to 64 exabytes of scratch disk space on up to four volumes. (An exabyte equals 1 billion GB.)
If your startup disk is a hard disk, as opposed to a solid-state disk (SSD), try using a different hard disk for your primary scratch disk. An SSD, on the other hand, performs well as both the primary startup and scratch disk. In fact, using an SSD is probably better than using a separate hard disk as your primary scratch disk.
— Scratch disks should be on a different drive than any large files you are editing. —
Scratch disks should be on a different drive than the one your operating system uses for virtual memory.
RAID disks/disk arrays are good choices for dedicated scratch disk volumes.
Defragment drives with scratch disks regularly.
https://helpx.adobe.com/photoshop/kb/optimize-photoshop-cc-performance.html
