Hardon hydro custom cooling (request for dimentions)
i have come to a liking of the hardon hydro, however, not the kit.
first, i really dislike aluminiums radiators, and i really think the fin density could be much more higher.
second, i do not like green, so the green liquid that stands out really well, i don't like it, i want pure water in it
and so for the reasons, i would like to custom water cool it..
so i would need to know the thickness of the radiators (if you know, which ones are compatible?)
and then is the pump res combo compatibility,what are the sizes of the pump res combo?
and what kind of mechanism locks the combo in place?
and how thick can my fans be?
I know the Alphacool DC-LT with a plexiglass top and with this res http://www.alphacool.com/product_info.php/info/p1057_Alphacool-reservoir-individual-for-DC-LT-pumps.html  will work. Already used it once.
Don't  have the build anymore so I don't have the radiator specs. Sorry
I did  use most of the EvGA water cooling kit. Just not the res as it leaked within two days of running. Seemed to be a known problem. Evga sent me a replacement but I didn't use it.
