Hello everyone, im pretty new to these forums and fairly new to pc building just built my first pc in august. I have a Samsung 840 pro 512GB all configured with my os and most used applications. I bought an internal hdd about a month ago and i went through 4 western digital drives from various retailers that just did not work. They would not show up in device manager or in my bios. The last 2 hard drives i have gotten have been a little more of a problem though. When i connected the sata power and fired up my pc these drives literally sparked up almost looking like they caught fire! (i have a 900D so i had a pretty good view of it) Then after i unplug my pc quickly i can smell a nasty burnt smell. On the 1st of the 2 that did this there was no external evidence but i was too scared to try it again so i immediately sent it back for rma at newegg since this drive was only received that day. The replacement for that one that i received was a little more visual tho, i again attached sata power and data to the back up the drive then i went to power it up and it did the same thing again... this time i decided to try a different sata power cord (the one connected to my dvd drive) again when i fire up my pc the hd as well decides to literally fire up, this time i could see clear visual evidence that this thing caught on fire the pcb has a black spot now. So basically i don't know where to go from here and do not know how to trouble shoot this. Any help will be greatly appreciated.
Jus in case here are my system specs
Intel i5 4670k 4.4 stable
Asus ROG Hero LGA 1150
2 GTX 780 reference (mild overclock)
corsair 1600 4x2 ddr3 memory
corsair ax 760
samsung 840 pro 512gb
corsair h100i
ive run stress test for 24+ hours (prime, heaven, memtest) and my system is stable no crashing or no error in memtest.
here is a picture of the hard drive sorry its kinda blurry i took it with my phone
http://i.imgur.com/41AaAnM.jpg
get a dmm, buy a cheap one if you have to, measure the sata power cable outputs and see if they're within specs (I'll try to edit in the specs in a few minutes), that sounds like your psu is delivering way too much current, or regardless something on your end is a problem, it's pretty hard to believe that you're getting tons of defective drives
Wow. Firstly, cool high end build. Next, it sounds like the PSU is bad in some way. Giving bad power to the SATA cables, too much it seems. This could have caused the first 4 to not have been registered, not sure about that though.
Keep vigilant, the problem will be solved eventually. I commend your patience thus far.
**EDIT: have you tried using a different connection on the PSU itself for the SATA power cable? Pretty sure that's a modular unit. I would replace it anyways, just a thought
what is a dmm? i googled it and it came up with some mountain climbing gear lol, yah im kinda leaning towards a defective psu as well i jus dont understand how it has not toasted my ssd or my gfx cards
digital multimeter
critical motherboard components, cpu, and gpu have their own power regulators, the ssd I have no idea
thank you very much kind sir, is there some sort of program i can get to measure the current going through the SATA cables? yea when i first installed my os via usb i was getting blue screens out the a** and my windows update was not working at all so i didnt really have the greatest first build experience but it did teach me to be patient with building.
On the drive in the picture i plugged it into a completely different sata power and data cable that was connected to my dvd drive and working just fine. Also the power cable connected to my ssd has a daisy chain and both drives sparked up on that cable so i dont think it was any of the cables
As far as testing the power levels on the cable, follow overlordnick's advice and get the Multimeter. As he said, there are cheap ones (harbor freight 10USD) but get a good one for the sake of reliability and durability.
I must stress that it's not a good idea to keep messing with this PSU. Faulty units can be dangerous, as you've witnessed. Please RMA your PSU
