I’m running Linux Mint 19.3, I don’t know much about Hard Drive failure because the only drive I’ve seen die is an xbox original hard drive.
I have a 10 year old 3 TB Seagate that currently loads in Gnome Disk Utility as an Unkown drive with large amount of bad sectors.
crtl+s: self-test failed.
when formatting
error formatting volume
mkfs.ext4-F -L exited with non-zerp exit status 5:
superblock backups stored on blocks
32768 etc.
Warning had trouble writing out superblocks udisks-error-quark,0
Don’t care about data I’m just trying to learn how to best detect hard drive failure, what can be done and when to recycle which is probably now.
Run a SMART test to get some diagnostic output, but what you are seeing currently is text book HDD failure.
https://www.snapraid.it/faq
“If you see one of the SMART attributes Reallocated_Sector_Ct (5) , Reported_Uncorrect (187) , Command_Timeout (188) , Current_Pending_Sector (197) , and Offline_Uncorrectable (198) different than zero, replace the disk”
k thanks, and to clarify I’ve yet to find away to use the disk. Can’t format or mount, but I can still see it in gnome disk’s.
smartmontools is your friend, but it’s dead, it’s dead
Gettings a reported0_uncorrect(187), Command-Timeout(188) must be a sign of Hard Drive Failure
