I've just dissassembeled my laptop and took the hard drive out off it http://www.newegg.com/Product/Product.aspx?Item=N82E16822136391
Would it be compatible with the sata 6gb/s?
If it is, can I safely extract the things I have there to my computer? I'm a bit worried since it still has windows xp in it and I'm plaaning to use it for a linux dual boot on my computer
