Halo Tritton Warhead Static Problem
There is always a phss/static noise emitting from my headset. I've come through and done all the possible solutions listed on Tritton website (http://support.madcatz.com/Knowledgebase/List/Index/132/halo-4-warhead) but none seem to have worked. Support gave me 2 "solutions" before telling me to RMA it but I don't want to because my headset would end up being replaced with an inferior one. I feel like something is causing interference through the headset but I can't figure out what it is (I went ahead and unplugged everything near the Xbox, turned off my phone, laptop and unplugged my routers). Every other aspect of the headset works flawlessly.
The headset is hooked up directly to my Xbox through the digital audio slot, I've also tried analog but that did not solve the constant in/out static.
Any suggestions?
this static noise could be caused by the RCA connection (red and white). or are you using optical?
another thing that could cause this is a short in the power board and your are hearing it through the headset speakers. all most like when you'er using the headphone inputs with powered USB on the front panel of a desktop you can hear the power going to the USB ports.
The headset is comes with 3 pieces: The base, power brick and headset. It is not a PC headset and is only functional with the Xbox. The base transmits the game volume front whichever audio cable you are using (I am using digital with my Xbox plugged in through HDMI). The base would then sync the headset with the controller and base to transmit the chat and game audio 100% wirelessly.
* I just went  ahead and explained that because multiple times I have been told to try solution only applicable with a wired headset.
I tried using analog audio but the static stayed and I would lose most of the Surround sound features, I went back to optical. Can I verify the board to make sure that a short is present? I don't want to RMA, lose the limited edition headset and still have the same problem.
if the static noise has always been present then it could be the wireless emitter if its something that started recently try a different power adapter (universal power adapter)
i would not recommend taking it apart.
It always existed since I started using it (1 month of use so far)
