Half of My parts came!
Other than case everything came, i opened up everything already and also putted back, does it matter if it sits there for 4-5 more days? Over here in NY it is pretty cold btw, and the mobo specially was really cold
Should be fine.
Nah, you should be fine. Just be sure you don't have any condensation when you do you initial build.
Yeah you should be good. Although why would it be an issue? Are you leaving them outside or something? lol
Now prepare for the longest wait of your life haha
ahah, this is my first build, you can say the issue is I am super overwhelmed
Do you think I should connect everything on the mobo?
Just wait for the rest of your parts lol
you can put it together to test if you want.
So i just leave the heat sink on it ?
you can leave the cpu,ram and heatsink/fan on while you put it in the case later and its a good idea to test it first before you put it in the case first to make sure it posts.
run a memtest86+ as well to check your ram, your looking for 0 errors. i had some and it caused bsod's one mention of memtest86+ error in an email and they sent me out new ram (corsair by the way, they sent when they received it)
