Hackintosh-First Full Build
Suggestions?
I will be using it for video editing and gaming (dual booting with windows 8)
http://pcpartpicker.com/user/FireclawX/saved/tVBTwP
for the most part, it looks solid. however, i'd shy away from the z97 platform till we see some more results in terms of compatibility with macOS. also, when selecting a graphics card, you should try and go with reference designs. some gpu's aren't compatible with mac. i.e.: my zotac gtx 780 amp'd edition. my reference model works just fine though. another thing i might suggest is getting a boot ssd to put your OS's on. and maybe more raw storage than just 1tb. games are only getting bigger, and raw video is absolutely massive and adds up very quickly. plus, the more games you have, the less room you have for footage.
