Hackintosh don't hate it's not for me
http://ca.pcpartpicker.com/p/TPVvkL will this work with osx
The 960 from what I've read is not hackintosh-able
the 970 ? http://ca.pcpartpicker.com/p/h28tBm
Grammar dont hate is not for you either. :)
i speak french so sorry im not good in english
The 970 is hackintoshable but from what I've read it is spotty at best and not recommended. The R9 290 and 290x are though. Apple moved away from using Nvidia products so the driver support isn't there. OSX likes AMD though.
witch one do you recommend for the same price as the 960
the r9 280x or r9 285
so this will be good http://ca.pcpartpicker.com/p/QNzVTW
Sorry about that! I was just playing around.
Now, regarding your card, I think that theu recommend a 750W minimum for the 290 so you might wanna to look into that.
I did some more research and the r9 290 does work but you have to do a slight modification in the os. The 290x on the other hand does work out of the box from what I have seen. I watched this video: https://www.youtube.com/watch?v=bWeABF7sTB8 and then read up on a couple forums and its supposed to be ok. But I put no guarantees on anything hackintosh.
the 280x or 285 will those work out of the box because the r9 290x cost to much for is budget or any card that work out of the box under 320$ us 400$ cad
The 280x is just a rebanded 7970, so the 280x should work, but it won't show the boot-up screen (everything else should work though).
and the r9 285 ?
I can't find anyone saying that the 285 does or doesn't work. I would just go with the 280x frankly.
thanks
