Whats up folks I wanted to get some insight on this build. I been fumbling around with different components and came up with this build for my budget, which is 3-4k. I plan on using 32-48GB of availabe RAM for a Scratch RAM DISK for rendering over a RAID 0 SSD config. Secondly most of my current software is MAC based so thats the reason behind the Hackintosh build. Here is my list http://pcpartpicker.com/p/zdIB
CPU: Intel Core i7-3930K 3.2GHz 6-Core Processor ($499.99 @ Microcenter)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($99.99 @ Newegg)
Motherboard: Gigabyte GA-X79-UD5 EATX LGA2011 Motherboard ($269.99 @ Newegg)
Memory: G.Skill Ripjaws Z Series 32GB (4 x 8GB) DDR3-1600 Memory ($169.99 @ NCIX US) Memory: G.Skill Ripjaws Z Series 32GB (4 x 8GB) DDR3-1600 Memory ($169.99 @ NCIX US)
Storage: Samsung 830 Series 256GB 2.5" Solid State Disk ($189.99 @ Newegg)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($137.98 @ SuperBiiz)
Video Card: Asus GeForce GTX 670 4GB Video Card ($426.98 @ SuperBiiz)
Case: Cooler Master HAF 932 Blue ATX Full Tower Case ($174.98 @ Newegg)
Power Supply: Corsair Professional 750W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply ($119.99 @ Newegg)
Optical Drive: Asus BW-12B1ST/BLK/G/AS Blu-Ray/DVD/CD Writer ($59.99 @ Newegg)
Monitor: Asus PB278Q 27.0" Monitor ($648.00 @ Amazon)
Other: Cooler Master 140 mm Fan ($11.00)
Total: $3116.84
If you can build a better rig or have any suggestions it would be much appreciated thanks in advance.
