H80i fit my case?
Hey,
I have a Nexus Clodius Ventilation Pro case. Now since i dont have a whole lot of room left in the case as it is, and i'd like a h80i, i was wondering, would it fit, and where would i have to put it?
CPU: FX 8120
GPU: R9 290 tri-x
2 HDD's
3 case fans
CM G700W
Might be a really tight fit. I had my NZXT that had the fan right up against the side panel. Really tight fit but it did fit. I had to lay the case sideways and then push it closed.
Where do i have to place the radiator Block? At the exhaust right?
