H60 and Mobo problem, HELP
Ok so i just bought the H60 cooler and a motherboard and i am almost done hooking it up and i notice the pump has a 3 pin connector instead of a 4 pin, and my motherboard doesnt have a 3 pin, just two 4 pins for fans...
Am i screwed and have to return it?
H60 http://www.newegg.com/Product/Product.aspx?Item=N82E16835181030
Mobo http://www.newegg.com/Product/Product.aspx?Item=N82E16813130738
