I have a corsair h105 and control it with msi command center(g45 z87).
I was wondering about speed and voltage of the pump, since it's connected as a fan, command center will ramp up the speed if the cpu gets hotter. SO:
Are fans controlled digitally or does the motherboard increase the power?
If the mobo sends more power, is there a desired speed/will the pump get damaged if it gets too much/too little power?
