H100i Question
I hope this hasn't already been asked, but anyways here goes... I just recently built my first custom pc and haven't booted it up yet because of one nagging question that I keep asking my self and my friends and have yet to get a good answer. I'm using an H100i, z87 sabertooth, i4770k, all in a design R4. I really don't want to use corsair link because I don't like the look of having a bunch of wires plugged into the pump of the H100i and the thermal armor on the sabertooth wont allow enough cable to run the corsair link cable behind the mobo so it would have to go down the front and that looks like crap. I would like to plug both of the radiator fans into the motherboard in the cpu and cpu opt headers, hook up sata power, and plug in the single wire fan plug into a random fan header on the mobo. Then I would hope to be able to control all of this from AI suit because I really hate having a lot of software installed that's not needed and I will be using ai suit anyway for my case fans. So i guess my question is can the h100i run properly this way or am I just gonna have to live with poor cable management and use corsair link. The only other corsair part in my build is my hx850 psu so i have no use for link. Thanks in advance.
I'm pretty sure that the only purpose of the single wire fan connector is to trick the CPU fan header into thinking that a fan is attached. I'll have to look at my H100i to confirm this when I get a chance. If that is the case, you will only need to apply SATA power to the pump and the two fans can be attached to the CPU fan headers. I don't know how advisable your intended setup is, but I'm pretty sure that it will work. Personally, I'm a fan of the Corsair Link software and the look of the wiring coming off the CPU block, but I can understand that it isn't for everyone.
Yea call me crazy but i just decided to get everything i had ever dreamed of having in a pc so i wanna keep it neat. I may use the corsair link if i have to but i really don't want to, I would love to know if i can go without it.
