H100i fans spinning at different RPM
Hey, I've got an H100i, and i can't get the Corsair Link software working on Windows 8.1 yet, they haven't released an update. I was wondering if it is potentially a problem that each of my fans are spinning at vastly different speeds. one seems to be going a bit closer to 2k rpm and the other appears to be closer to 1k rpm
Now, i've not seen any temperature issues yet, in fact I've not seen the CPU rise above 50 degrees Celsius, but I was wondering if I could eventually have an issue on my hands.
How do you have the fans setup? More specifically, are they plugged directly into the MB? Are they plugged into the pump/waterblock? Are they both on the same splitter coming out of the pump/waterblock? Something else?
They are both plugged directly into the motherboard, yes they are both plugged into the waterblock and there is only one cable coming from the waterblock as i can see. They are set up to push air through, so under the radiator with the air flowing upwards and out the case.
They are both variable speed fans as well.
With the way the H100i works, the fans are either going to be plugged into the splitter that comes out of the waterblock, or they're going to be plugged into the motherboard. Your answer makes it sound like both... Can you clarify, or maybe take a picture of how it is setup?
The waterblock has a few things going on. There is a USB cable that runs to a USB header on your MB, and that is what controls the Link software. Then there is one cable that comes out and splits into SATA power and a single wire that plugs into the CPU fan header. Here is where the fans come in: there are two plugs on the waterblock where a proprietary fan splitter plugs into each. The fans that are attached to the radiator are intended to be plugged in there, and those are controlled in the Link software. If you have the radiator fans plugged in your motherboard, they could very well be spinning at different speeds depending on what your MB is telling them to do.
Corsair Link received a BETA update a month ago which enables 8.1 support.
http://forum.corsair.com/forums/showthread.php?t=125350
