h100 vs h100i
I am looking to retire my hyper212 evo that is cooling my I72700k with sp 120s in push push. My question is wich one should I buy?  I will be using my sp 120s instead of the fans that come with each unit.
H100i will give you lower temperatures.
Im just woried because he h100i has alot of issues atm.
Like what? I haven't heard of any.
Read some reviews,leds wear out and the fans have some niose issues as well as some others.
There is also the h110 or the nxzt cracken
The h110 and the kracken x60 will not fit in my case. The only thing that should fit in the corsair 200r is a 240mm radiator with 50mm thickness with fans.
Swiftech H220!
YOU ARE ALL WRONG. Logan reviewed the xigmatek dark night and said that on load it gets lower temps than a h100, it is cheaper and there not faffing around with the rad and stuff. Go for that instead.
 Xigmatek dark night will not fit in the corsair 200r as the hyper 212 evo barely fits.
http://www.xigmatek.com/product.php?productid=162&type=specification
http://www.coolermaster-usa.com/product.php?product_id=3053
They are the same height, measuring in at 159mm. Just something to think about.
Its funny because they ARENT wrong, the xigmatek might give you slightly, just slightly, better temps but so do a lot of other cooling units.
To actually answer the question; Yes a h100i will give you better performance than the h100. If the fans suck, just replace them, thats what you gotta do with mosty stock fans.
