My H100 was working fine for about a year, but recently the molex cables have gotten severed, causing the pump to stop working (Picture in imgur link)
http://imgur.com/Sj0ejd5
I've seen a couple cable fixing videos that involve just twisting matching wires together and securing them with electrical tape, but none seem to work for my case.
The actual molex connector (plastic part that holds the cables) is fine, and I have a few extras lying around. But i would need to get new connections for the end of the cables and have to solder the cables onto them, which I don't know how to do very well, and would like to avoid if possible.
Since I have some extra molex connectors from my power supply that I don't need to use, could I possibly cut the wires on the working molex connector, and just use electrical tape to connect the 2 broken molex cables to the working ones? And how would I go about doing so?
