So my H100 fan controller (not the pump) seems to have died. The fans doesn't spin, LEDs don't light up, button doesn't react. I've tried doing that 1 minute/ 5 sec button press reset process with no luck. Anyone have any other advice to try to fix it. Otherwise, anyone take apart an H100? I was thinking of cramming an Arduino and some LEDs.
Option 1 - If warranty is still valid just rma it - its a pretty common fault and you may score a h100i as a replacement.
Option 2 - Just run the fans off a motherboard header or molex. Its better like that anyways.
Option 3 - Its easy enough to take apart the h100 the outer casing comes off with very little work - be aware though that the warranty will be void. Head here for an in-depth look inside. http://www.xtremesystems.org/forums/showthread.php?277795-CORSAIR-H100-Inside-The-Block-And-Pump-Preview
So I took it apart it seems there's a component on the logic board that gets really hot. It's between capacitors C2 and C4 and it's right next to the wires of the incoming voltage.
Also the motor has 3 wires VCC, GND, FG. Anyone have a clue about FG? and the temperature sensor has only 2 pins, Any clue on how to get reading from it?
