Ok, I am having this problem with GUIMiner. I go to open it and it says it has launched but nothing appears on my screen. Help??
if you are useing windows, check in the popup menuĀ on your task bar
Yeah, I do. When I however over the box in my taskbar, it comes up with a preview of the window. But I can't acatually get that window to show on screen D:
its the config files, just go to User>*whatever your suername is*>appdata>roaming>poclbm and delete the files in there
Oh and you shouldnt be able to see appdata unless you open my computer, go to oragnize in the top left>folder and search options> show hidden files and folders.
Cheers buddy, worked like a charm :)
