Will it work always as it should or should I get a 780ti and be done with it? Will a 780ti do 1720x1080 @ 144FPS? Will the SLIed 770s do 144FPS on the above setup? Oh, and does running a 1680x1050 monitor on the side to browse the web while gaming reduce FPS?
depends on how much video memory you have.
2GB per card
