Will the Asus GTX770 fit in this case?
The motherboard is a ASUS Z87I-Deluxe
Thanks!
Thanks!
The Motherboard will fit but the GPU will not. the amount of headroom for a GPU in that case is about 7 inches. The Good Majority of Gaming Cards are 10 to 11 inch cards. however you could probably grab MSI's GTX 760 Mini ITX Card. or Asus 760 Direct CU Mini. both of those cards are roughly 7 inch cards or 178mm
thanks!
