Hi there everyone. I plan to build my first rig after Christmas which will be primarily for gaming and programming (defecting from consoles). I plan to start off with just a single EVGA GTX760 as this is the best card I can get in my budget. I am not really looking to be playing games maxed out and everything but I just want to run games that look nice at good FPS. I will just be starting off with a single monitor plugged in via HDMI. In the future however I am planning to look into having 3 monitors running off the one card. Will this card be okay to do that or will it be better to run another in SLI so that it works. I would prefer to only have to have one card as it is all I can afford and this is my first build/rig of mine.
Thanks for all the help and if you have any tips or whatever don't hesitate to put them forward. I need all the help I can get.
