l am looking at building a computer and I wanted to know the difference between these two 980's. The price difference is pretty significant and it seems that the the only differentiating factor is how it looks.
http://www.amazon.com/gp/product/B00NI5NCRW/ref=ox_sc_act_title_5?ie=UTF8&psc=1&smid=A1TSN35NIS24VZ
http://www.amazon.com/EVGA-GTX980-Superclocked-Graphics-04G-P4-2983-KR/dp/B00NT9UT3M/ref=sr_1_1?s=pc&ie=UTF8&qid=1418686008&sr=1-1&keywords=gtx+980&pebp=1418686022358
The first one is a reference design the second has the ACX cooler on it.
The ACX is cheaper, has higher clock speeds and will run cooler and quieter.
Personally, I wouldn't get either. The 980 is pointless to me. It is $200+ more than a 970 for about 5-10 more FPS. Hardly worth it.
For the price of one 980 you could get two R9 290s and that would destroy it.
So I say get a 970 or two R9 290s.
Thank you. I just looked for the top of the line in GPU's. I am building a computer for a family member and the buget was pretty high so I was thinking about putting two 980's in there. Is there a better alternative?
How is the GTX Titan and the 780?
Well the card with the ACX cooler is the best card of those 2.
That card is cheaper on newegg by the way
EVGA: http://www.newegg.com/Product/Product.aspx?Item=N82E16814487079
More Decent GTX980´s
Asus GTX980 Strix: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121905
Zotac GTX980 AMP Omega: http://www.newegg.com/Product/Product.aspx?Item=N82E16814500359
Msi GTX980 Gaming: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127834
