GTX 970 Reference Card
Hi guys,
I am looking for the Nvidia GeForce GTX 970 but in the form of a reference card, i have been unable to find one in any UK based computer shops. Does anyone know if they are available in the UK let alone if they even exist.
Thanks Guys
http://www.overclockers.co.uk/showproduct.php?prodid=GX-205-OK
OcUK apparently have exclusivity in Europe with the reference design. http://forums.overclockers.co.uk/showthread.php?t=18629271
I believe these cards use a reference PCB, but have different fans.
http://www.scan.co.uk/products/4gb-gainward-gtx-970-7010mhz-gddr5-gpu-1051mhz-boost-1178mhz-1664-cores-3x-mini-dp-1x-dvi-1x-mini-hd
http://www.scan.co.uk/products/4gb-palit-gtx-970-7000mhz-gddr5-gpu-1051mhz-boost-1178mhz-1664-cores-1x-dvi-i-3x-mini-dp-1x-mini-hdm
Thanks for the super speedy reply, i shall look into getting this in the future, i wanted the reference because sooner or later the corsair HG10 will support the 970 and 980 so i can get some cheeky water cooling
