GTX 780 vs. R9 290
Ok so my budget on my GPU is $500  max.
and since the r9 290 went up to $500 I can compare it to the GTX 780.
So which one should I go with? I'm really not sure on which one to get.
Ill be gaming on 1920x1080 with one monitor.
And I want it by Christmas....
780
Depends, 290x is a bit gimped without 3rd party cooler available from the major manufacturers.  780 is probably better at 1080 though while the 290x will pull ahead at 4k.
I'm a AMD fan and user, but I don't trust the 290's and 290x's temps. I would take the 780
If you're gaming on a 1080p monitor, you could max out all but a few games on a GPU that costs $250-300.
But if you want serious power for whatever reason, I would take the 780. It is quite right that the R9s could be gimped because of the cooler. This is shown in overclocked benchmarks where the 780 tends to pull ahead after overclocking.
Shame the R9s went up in price.
